Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Overlander > 1965 - 1969 Overlander
Old 11-26-2013, 06:01 PM   #1
groovzilla's Avatar
1963 19' Globetrotter
Seattle , Washington
1968 overlander window removal
all,
had a productive day today removing the window channel/hinge piece that holds the curved window glass. many thats to bruce(68 TWind)who has extensive knowledge restoring the 68 model - he guided me thru the process and i thought it would helpful for others to view photos of the process since it is a hard one to figure out. what is especially difficult is when a previous owner uses an epoxy glue to install plexiglas as a replcement - the glue was like metal and i had to use my heat gun and a heavy duty scraper/hammer to break the bead once it was heated up - the photos below show the process and hope they are helpful.
there is a small angled piece of aluminum trim on both top corners that holds the channel piece into place - in order to remove the channel these angled pieces must be removed - the channel is then lifted in the up postiton and should slide left or right - i had to slightly bend up the small trim piece that is riveted on the trailer in order to gain enough clearance for the channel to slide out.
ID:	200741   Click image for larger version
ID:	200743   Click image for larger version
ID:	200745   Click image for larger version
ID:	200747   Click image for larger version
groovzilla is offline   Reply With Quote
Old 01-14-2014, 06:16 PM   #2
desertair27's Avatar
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
Nice work!
Thanks for posting.
Mike
desertair27 is offline   Reply With Quote
Old 05-07-2018, 03:35 PM   #3
1968 24' Tradewind
parker , Colorado
I know this is an old thread, but thanks for taking the time to post. I would have never figured out that the aluminum angles were what keeps the window hinge from sliding out sideways. I will give it a shot.
Venturewest is offline   Reply With Quote
Old 05-08-2018, 10:05 AM   #4
groovzilla's Avatar
Glad the window removal post helped!
1968 22' Safari - All Original
