Old 07-14-2019, 02:32 PM   #241
Joyflea's Avatar
1967 26' Overlander
Alpine , Texas
Well I was trimming down some of the old doors and found why they are so light . Filled with cardboard . Was worth a try .
Started yesterday doing a little late spring cleaning , moving everything around to get the Airstream in the carport next to the shop , much cooler. Moved a station wagon project , will be our tv for the AS. . Also moved the four post lift . Will finish up in the morning.Click image for larger version
Joyflea is offline   Reply With Quote
Old 07-14-2019, 03:02 PM   #242
Hot Springs Village , ARKANSAS
Hello all, just purchased 1992 AS Excella 1000..plan on doing renovation to interior. It has a very musty smell. Was in storage for 2 years. My question is how do I know if I need to replace..almost afraid to find what behind them..Any suggestions appreciated.
clarsen0829 is offline   Reply With Quote
Old 07-14-2019, 05:03 PM   #243
Joyflea's Avatar
1967 26' Overlander
Alpine , Texas
Clarsen0829 , recommendation to post this on the main board . You would get a lot more suggestions. Good luck with your project .
Old 07-14-2019, 08:14 PM   #244
NO HUMBLE OPINION
ALUMINUMINUM's Avatar
1968 20' Globetrotter
ANN ARBOR , THE GREAT LAKES
Nomads Rule...
'59 Nomad with LS3...?? Sweet
ALUMINUMINUM is offline   Reply With Quote
Old 07-15-2019, 06:07 AM   #245
Joyflea's Avatar
1967 26' Overlander
Alpine , Texas
1959 Nomad was a 4 door . 58-60 4 door . The 2 doors for those years were Brookwood.
It’s got a custom chassis already built with a 2” receiver hitch and progressive spring in the rear . It was my wife’s dream car . 2008 LS3 with a six speed .
Old 07-16-2019, 06:13 PM   #246
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
I too noticed that was no 283 V8 in that 59.
How many complex projects can a guy handle all at once?
David
WBCCI #8607
VAC Region 11
See my 1969 Globetrotter 21' Renovation Project:
In Knowledge Base
See my 1966 Trade Wind 24' Reno Project:
In Knowledge Base
See my 1975 Overlander 27' Improvement Journal:
In Knowledge Base
See our 1976 Sovereign 31' Renovation Project:
In Knowledge Base
Old 07-16-2019, 06:58 PM   #247
Joyflea's Avatar
1967 26' Overlander
Alpine , Texas
How many you got . It helps to have ADD and lots of coffee.
Old 07-16-2019, 09:15 PM   #248
2007 22' International CCD
1967 project , THEbig fix! .
Well, I’m not a coffee drinker, but I hear you on the ADD and will raise you OCD on my part.
Old 07-18-2019, 02:16 PM   #249
Joyflea's Avatar
1967 26' Overlander
Alpine , Texas
Progress ?
Well everything is moved and arranged. Set up my table saw under the fourpost lift . Other than that I did a little spray painting , primer , sealer and white paint . 7 Coates in all and only took 5 hours . Dry time and sanding added up to 7 hours . BlueClick image for larger version
Old 07-21-2019, 02:34 PM   #250
Joyflea's Avatar
1967 26' Overlander
Alpine , Texas
Sold my truck camper today , so we get to eat this week !
Mounted all the painted parts from last time I posted . All but end panel is in place . Need to get the countertop done first . When I cleaned and moved everything I found some quarter sawn oak . Started planning it this afternoon . Made a lot of chips since I started with 5/4 thick wood . Anyway got one side done and will finish up tomorrow when my plane is cooler . Beautiful grain . Setting the stovetop and sink in place to get my measurements. The microwave is in place . Blue
ID:	347263   Click image for larger version
ID:	347265   Click image for larger version
ID:	347267   Click image for larger version
Old 07-22-2019, 07:25 AM   #251
islandtrader's Avatar
1956 22' Caravanner
Don Pedro Island , Florida
. Started planning it this afternoon . Made a lot of chips since I started with 5/4 thick wood . . . Blue
I have learned one thing about planning...vacuum dust collector bin.
My Rebuild page : 1956 Caravanner
https://www.airforums.com/forums/f11...ml#post1921527
islandtrader is offline   Reply With Quote
Old 07-23-2019, 02:02 PM   #252
Joyflea's Avatar
1967 26' Overlander
Alpine , Texas
Well I got all the oak planned , jointed , squared up , and glued . I did a fit up for the wall piece first and made sure it was even with the front , then added three more to make it 3/4” of over hang in the front . After it dries , I will sand it nice and flat and cut my holes for the sink and stove top .
Also sprayed some sealer on a couple of doors and another over bed cabinet .
Hope to get the galley cabinet done before I leave on a motorcycle trip next Friday .
Blue
Old 07-24-2019, 07:28 AM   #253
1956 22' Caravanner
Leave on a motorcycle trip? Let's see the first full week in August ?
Could it be you are heading for Sturgis ?
Old 07-24-2019, 03:18 PM   #254
Joyflea's Avatar
1967 26' Overlander
Alpine , Texas
Go to the black hills every year . 1979 was my first , so this will be my 40th Anniversary. In those 40 years only missed 6 . Don’t always stay in Sturgis , to crowded , but ale it up there. Some of the best riding in US . Doing an antique meat this year .
Old 07-24-2019, 06:35 PM   #255
1967 26' Overlander
Seguin , Texas
I’ve been stalking your posts! Great work. Just curious, where did you order your black and gray tanks? I’m about to drop my black and I’m thinking hard about installing a gray. Thanks for all your great post! You truly are passing on some great knowledge.
1967Over_Int is offline   Reply With Quote
Old 07-24-2019, 07:26 PM   #256
Joyflea's Avatar
1967 26' Overlander
Alpine , Texas
Black from Airstream supply gray off the Internet.
Old 07-25-2019, 06:19 AM   #257
1956 22' Caravanner
Good for you...over the years I have been 1/2 dozen times. I think my last time there was for the 50th! Thats the last ride pin that I can find. As far as the riding you are spot on. One day on main street just to see all the bikes and then head for the hills. Enjoy.
Old 07-27-2019, 01:28 PM   #258
Joyflea's Avatar
1967 26' Overlander
Alpine , Texas
Counter top all sanded , holes cut for cooktop and sink . All trimmed and fitted . Put the first coat of stain on and will do second before I go to bed tonight. Love the way the stain makes the grain pop . Hope to start the clear tomorrow. Blue
Old 07-28-2019, 06:44 PM   #259
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Looking good. I gave thought to a natural wood countertop but the boss insisted on laminate. Oh well, I do what I'm told.
David
WBCCI #8607
VAC Region 11
In Knowledge Base
In Knowledge Base
In Knowledge Base
In Knowledge Base
Old 07-30-2019, 01:45 PM   #260
Joyflea's Avatar
1967 26' Overlander
Alpine , Texas
Got my third coat of poly on the countertop. I think it looks nice . Leaving for an antique MC show at Sturgis tomorrow after a couple of appointments. When I get back I will decide if I’m going to put some satin on or leave it shiny. Going to be putting a little something different on the backsplash and will decide if I want the reflection. I love the way the grain came out .
Latter , Blue .
Seeking a 19-21 foot project trailer for Food Truck project debbooooo Airstream Classifieds 0 09-06-2016 01:00 PM
California project trailer - fix title now? kaulike Title, VIN & Registration 9 06-05-2012 04:48 PM
To fix or not to fix nayl Ribs, Skins & Rivets 16 07-17-2010 08:38 PM
1967 Airstream Overlander 27' Good Project, Polsihed! eBay Watch Airstreams on eBay 0 05-27-2009 03:40 PM
You Fix-You Camp-You Fix Some More juel Off Topic Forum 6 08-18-2005 07:50 AM
