10-11-2003, 05:08 PM
Retired Moderator
1992 29' Excella
madison
, Wisconsin
Getting ready for the freeze-Winterize
that time of year again.
this time i added a little gadget to make adding antifreeze a little easier.
just a little three way valve....
i'll go through all the steps of winterizing for newcomers to cold climate airstreaming.
here are the supplies.....
john
you call them ferrets, i call them weasels.
10-11-2003, 05:10 PM
Retired Moderator
1992 29' Excella
madison
, Wisconsin
my existing pump setup
in the bottom of my closet
10-11-2003, 05:13 PM
Retired Moderator
1992 29' Excella
madison
, Wisconsin
make sure the valve...
is the right size and faces the proper direction.
otherwise you will not be able to draw antifreeze into the system.
10-11-2003, 05:16 PM
Retired Moderator
1992 29' Excella
madison
, Wisconsin
installed
here is what it looks like installed...
i used teflon tape on the threads, although not needed because of rubber o rings in the connections.
i used it anyway because of the plastic to brass connections.
10-11-2003, 05:18 PM
Retired Moderator
1992 29' Excella
madison
, Wisconsin
then i drained
the water heater
10-11-2003, 05:19 PM
Retired Moderator
1992 29' Excella
madison
, Wisconsin
then bypassed the heater
showing valves....
10-11-2003, 05:22 PM
Retired Moderator
1992 29' Excella
madison
, Wisconsin
low point drains
then i opened the two low point drains, one for hot one for cold.
not my wiring by the way.... factory original job!
10-11-2003, 05:24 PM
Retired Moderator
1992 29' Excella
madison
, Wisconsin
time for air
my home made adaptor, run at 60 psi.
10-11-2003, 05:28 PM
Retired Moderator
1992 29' Excella
madison
, Wisconsin
at this point...
i go around and open all the faucets and blow the water out.
after i am sure the system is purged, i shut off the air and close all valves and drains.
then i start the pump and again go around opening all the faucets and low point drains. not forgetting the shower wand and the hand spray on the toilet!
10-11-2003, 05:32 PM
Retired Moderator
1992 29' Excella
madison
, Wisconsin
don't forget the drains!
after the entire system has been filled with rv antifreeze i add a couple of gallons to all the drain traps.
i also wipe up any excess in the shower or sinks to prevent staining or collecting dust.
don't forget your outside faucet if you have one!
10-11-2003, 05:42 PM
Retired Moderator
1992 29' Excella
madison
, Wisconsin
that's about it, when finished i put the diverter valve to "normal" position, cap the opening, remove the hose and store in a zip loc baggie.
also i add a little antifreeze to the water strainer, there always seems to be a little sitting in there. the air cannot reach it because it is on the suction side of the pump.
also, the water filter element goes in a baggie too, stored in the house.
john
miller time!
10-11-2003, 05:54 PM
Another excellent class!!
John,
Nice job! Since I've never had the need to winterize my trailer, I'll book mark this for future ref.
Mac
p.s. How many "Miller's" did it take to complete this job????
10-11-2003, 06:02 PM
Aluminut
2004 25' Safari
Noticed the High Life made another cameo!
Nicely done!
Eric
10-11-2003, 06:19 PM
Retired Moderator
1992 29' Excella
madison
, Wisconsin
10-11-2003, 06:25 PM
1969 31' Sovereign
Broken Arrow
, Oklahoma
only 3 ????
10-11-2003, 06:29 PM
Retired Moderator
1992 29' Excella
madison
, Wisconsin
Re: only 3 ????
10-11-2003, 06:35 PM
Aluminut
2004 25' Safari
Rock on John....line 'em up an knock 'em down like a pro!
One day, were gonna have to have a few of those and talk some serious smack....
Eric
10-11-2003, 06:41 PM
Just an old timer...
2004 22' Interstate
Tipton
, Iowa
Re: p.s. How many "Miller's" did it take to complete this job????
Thank God, John! I thought for a minute you'd been reduced to drinking blue Dawn dishwashing soap!
Roger
havin' to fix my broken Airstreams since 1987...
AIR 2053 Current: 2004 Airstream Interstate "B-Van" T1N DODGE Sprinter
10-11-2003, 07:37 PM
Retired Moderator
1992 29' Excella
madison
, Wisconsin
Re: Re: p.s. How many "Miller's" did it take to complete this job????
Roger
rog
that blue swill! no way!
miller costs less ounce for ounce!!
john
10-11-2003, 09:28 PM
John,
Wow what a well done instructional for all of us. This has answered a couple of questions I have.
Leeman
