Old 06-12-2012, 09:19 PM   #1
Airstream Newby
CMSmith's Avatar
1975 25' Tradewind
Florence , South Carolina
Why not all Aluminum?
Seems like if Airstream had made the frame out of aluminum as well, that a lot of the issues being dealt with (frame rusting out and causing many other problems) would have never happened. Has anyone replaced a rotting out frame with a newly built aluminum frame? Is there a place to get these from for specific models?
CMSmith is offline   Reply With Quote
Old 06-12-2012, 09:43 PM   #2
Ottawa , ON
I'm not an engineer (nor do I play one on TV), but two reasons occur to me:
1. Without a complete change of design, the strength of aluminum can't equal steel, especially in places like the frame.
2. It would cost more. Yikes! That's enough all by itself!
Old 06-12-2012, 09:55 PM   #3
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
I am a mechanical engineer by degree. Steel has three times the young's modulus of Aluminum (30 million PSI vs 10 Million). You would need to have an aluminum frame cross section with 3 times the moment of inertia to come out equal in rigidity. It could be done. The thing that seems to fail the first on Airstreams is the wood floor and the rubber axles, so those are the area I would work on first, if I were to redesign an Airstream.
Old 06-12-2012, 09:56 PM   #4
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
There was a thread in the past regarding trucks that had cracked aluminum frames, etc. It's just too brittle under load and moving stress.
Many people think it should be galvanized though. The ones that go to Europe ARE galvanized, but they are also bolted together, not welded. And one weakness with galvanized metal is that a small gap in the coating can let in rust - and then it rusts behind the galvanized layer where it can't be seen until the part fails.
Didn't Uwe built a Stainless Steel frame for an Argosy he restored?
Paula
Old 06-12-2012, 10:00 PM   #5
Ottawa , ON
Good point. In fact, Airstream built a number of Argosy models with an aluminum sub-floor, years ago.
I have no idea why the idea didn't stick. It would seem to be an ideal answer to that old problem...
Old 06-12-2012, 10:06 PM   #6
danlehosky's Avatar
2012 25' FB Flying Cloud
Gig Harbor , Washington
I agree with Paula, hot dip the whole damn thing. An aluminum frame could be designed. Pernaps an I beam with with a 1" web and 6" flanges. I'd have to do the calculations. I'd feel comfortable with the material but not the welds. Machine welding might work under some very controlled conditions. Welding aluminum is difficult and I know people who can do it and have a nice looking bead, but how strong is it? A cold joint will snap like a toothpick if flexed under load.
Dan
TAC
Hope is not a plan.
danlehosky is offline   Reply With Quote
Old 06-12-2012, 10:07 PM   #7
Eric H's Avatar
1974 23' Safari
1947 25' Spartan , Manor
Stainless steel frame and floor would be so super sweet. It would last and last.
Has anyone used a hardy plank material for the floor? That seems like a good idea.
Eric H is offline   Reply With Quote
Old 06-12-2012, 10:13 PM   #8
1977 31' Sovereign
1989 34' Excella
Steel is more fatigue resistant that Aluminum. They make aluminum airplane frames, but they have a predicted useful life. Proper galvanizing is a sacraficial material for the steel frames. If properly done, even scratched galvanize will protect the steel from corroding until all the zinc is gone. Depending on how much salt they use of the streets the trailer is used on it will last a good long time. A great paint job over the galvanized steel is even better. Boat trailers, intended for salt water use, are hot dip galvanized.
Fiberglass foam core floors would stop the rotten wood floor issue.
Old 06-12-2012, 10:21 PM   #9
danlehosky's Avatar
dwight, I like the foam core idea, even ABS foam core would work well. It's been used in pipe for years, it's durable, quite flexible and the skin on the outside could actually be the floor surface.Aluminum is much more mallable than steel but depending on the carbon content of the steel it can be quite soft as well. It's been a long time since I've seen young's modulus referenced.
Eric,Hardiplank is a cementus material and would not withstand the flex the floor encounters as it travels.It's also heavy as hell.
Dan
Dan
TAC
Hope is not a plan.
Old 06-12-2012, 10:23 PM   #10
mefly2's Avatar
2015 25' FB Eddie Bauer
2013 25' FB Eddie Bauer
2012 20' Flying Cloud
Small Town , *** Big Sky Country ***Western Montana
Don't want an aluminum frame around here ...
Old 06-12-2012, 10:29 PM   #11
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Paula
Hi, Paula; That was BoatDoc who made that stainless steel frame.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
Old 06-12-2012, 11:29 PM   #12
tpi
Trabuco Canyon , California
Are cracks in aluminum frames repairable thru welding/doublers etc. in a practical manner?
tpi is offline   Reply With Quote
Old 06-13-2012, 01:42 AM   #13
1971 31' Sovereign
Los gatos , California
Ye you can with a specialized welding called TIG tungsten inert gas welding. The toughest to master in my opinion an expensive machines, but possible. Side note the skin in my mind is way to thin to TIG weld comfortably.
Chrispate is offline   Reply With Quote
Old 06-13-2012, 06:11 AM   #14
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Programmed life...
If any company built its' products so they would have an infinate life, they would eventually run out of need to sell and close shop as the market dried up!
Ironically, the current Euro spec Airstreams come standard with a galvanized chassis.... why are our US spec AS not built this way?
Anything zinc plated will certainly outlast something painted.
Old 06-13-2012, 06:37 AM   #15
"Cloudsplitter"
Especially if protected by a properly installed B-Pan.
Old 06-13-2012, 07:05 AM   #16
Airstream Newby
CMSmith's Avatar
1975 25' Tradewind
And this is why I am not a designer/builder of custom trailers. Apparently mine would fall apart or snap in half. Great insight.
Old 06-13-2012, 07:43 AM   #17
Wabbiteer's Avatar
Jupiter , Florida
mrgreen in europe somewhere just had his frame hot-dipped and they lost some bits of the frame as a bonus...
The days are short and the night is long and the stars go tumbling by.. . ~Airstream~
Old 06-13-2012, 08:25 AM   #18
Wayward's Avatar
Broadway , North Carolina
aluminum trailers
I spent a deacde or so working on boats and engines in a saltwater area of Florida. Only two types of trailers held up: hot dipped galvanized and aluminum.
Float-On trailers are all aluminum, hold up extremely well in extreme salt environments, and have been around for 30 years. Looking at them, you can tell the are engineered differently than steel trailers and are used on some very large boats
Float-On Features
2006 Safari SE FB
2000 F150 4.2L (retired), 2011 F250 6.2L, 2010 ML550, 2000 Excursion 7.3L
Broadway, NC
Old 06-13-2012, 08:42 AM   #19
Southwest Research, in San Antonio, Texas, tested an aluminum chassis in the late 1960's.
I saw it under test.
Bottom line results was an absolute "failure".
Andy Rogozinski
Inland RV Center
Corona, CA
Old 06-13-2012, 10:00 AM   #20
safari62's Avatar
1962 22' Safari
1957 22' Custom
1963 16' Bambi
Vacationland , Maine
Images: 43
here is photo of an actual Airstream frame IN OHIO.
Why are they not used in the US? Don't get me going.
wbcci #3363
VAC - Region 1 vintage Club rep
New England unit
safari62 is offline   Reply With Quote
