So the shell is off on the '73
Sovereign, and just an fyi, our AS will be on our property as a tiny home, not traveling. Given that, a few questions:
*On the frame, besides obvious rust repair and outrigger replacement as needed, what should I look for?
*Outriggers should be level with crossbeams, not sagging lower correct?
*For expense sake if we keep axles, and replace later, is cost much different?
*In replacing the subfloor, should I be removing the C-Channel, attaching to new wood, then lower the shell and rivet to C-Channel? Other wise I can't do single piece across width right?
*Since we ripped the floor out and most of it was rotted out anyway, I'm unclear if the C-Channel is supposed to sit fully on the outrigger? 2nd part, anyone know that actual dimension?
