Old 11-15-2021, 08:40 AM   #1
2015 23' FB Flying Cloud
Greenville , North Carolina
what does this look like?
*pics attached*
We have a 2015 23' FB. Out of nowhere we noticed this blotchiness on the floor at the space at the foot of the bed (front left side of trailer).
It is only in this one spot, nowhere else. I clean the floors every week and one day there was nothing, then the next week it looked like this.
I should mention that we run a very large dehumidifier at all times (I am very paranoid about moisture and RH levels!) and ironically enough the dehumidifier is located directly next to where this popped up!!
The staining is certainly underneath the vinyl, not on top of it, which is a scary thought to me because I have a sinking feeling its mold underneath the floor.
What do you all think, and what would be your next steps?
- I'm ordering a moisture meter to test it.
- Would you go at it from underneath the belly pan first, or just start pulling up the vinyl floor?
- Any idea what might be the moisture source? Only thing I can think is that our fresh water tank fill is nearby there, but we hardly ever use it since we are on city water.
We are full timers so it will be a big project to get a hotel and start ripping up the floor, but if it must be done, it must be done...
thanks in advance!
ID:	407965   Click image for larger version
nc.streamer is offline   Reply With Quote
Old 11-15-2021, 08:41 AM   #2
dznf0g's Avatar
Oswego , Illinois
Water leak with moisture under the flooring, between subfloor and flooring.
-Rich-
Old 11-15-2021, 10:53 AM   #3
2011 27 FB International
Spokane , Washington
Here are the steps I would take:
1. Pull up the trim on the wall and pull back the vinyl sheet. You can do that without turning it into a disruptive project. As someone who had water damage to the subfloor beneath the vinyl sheet, there was no visual evidence of damage on the vinyl itself, so I'm skeptical that it's water. If it is, you'll want to rule that out by taking a look. Also, is the floor soft there?
2. Does the dehumidifier you're using have rubber feet? And/or have you use a rubber bottomed mat or kept anything rubber there? The discoloration I'm seeing looks a lot like a rubber and vinyl reaction. I also had this issue, and regret to report that once the damage is done, there's no undoing it. It will look ugly until you replace the flooring. Would have been nice for AS to put out a PSA on that.
Fingers crossed that it's not water.
coltnkat is offline   Reply With Quote
Old 11-15-2021, 11:06 AM   #4
Lily&Me's Avatar
Normal , Illinois
It does look like it was caused by moisture.
Maggie
🚐 Interstate Owner Emeritus 🚐
🌹 Cherish and appreciate those you love. This moment could be your last. 🐚
Old 11-15-2021, 02:45 PM   #5
Thank you! We do sometimes put a rubbermaid tub right there, although it doesn't live there permanently. Interesting that it could be a reaction to the rubbermaid bin - I am crossing my fingers for that!
If we pull up some of the vinyl and it's not moisture, I imagine it's pretty easy to glue back down?
We may actually just decide to replace that part of the floor anyways if it's stained and hopefully it won't be too unsightly to have a square that doesn't match the rest perfectly.
Old 11-16-2021, 10:59 AM   #6
2017 28' Flying Cloud
Davenport , Florida
I would pull the city water hook up loose and look at the back mine leaked and made the same stain on floor .
hickman1 is offline   Reply With Quote
Old 11-16-2021, 01:44 PM   #7
"Cloudsplitter"
Easy to pull up because it's a 'floating floor'...no glue.
Old 11-17-2021, 08:06 PM   #8
Gulliver72's Avatar
2015 25' FB Flying Cloud
Barnstable , Massachusetts
Your floor is soaked and vinyl ruined. It has to be torn up, leak(s) found, sealed or repaired, and new flooring installed. Waiting risks more damage to plywood subfloor.
Gulliver72 is offline   Reply With Quote
Old 11-17-2021, 10:47 PM   #9
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
X2….yup.
wulfraat is offline   Reply With Quote
Old 11-21-2021, 10:57 AM   #10
kbmwrs's Avatar
2016 25' International
Morgan Hill , California
Glad to read that YOU actually went to their AS and inspected it and came to this conclusion.
They should be very thankful that you did this for them.
kbmwrs is offline   Reply With Quote
Old 11-21-2021, 11:03 AM   #11
Boulder , Colorado
Agree with prion posts regarding water leak. Same happened to us. Ensure that your sub-floor is COMPLETELY dry, or replaced before laying new vinyl, or you will be doing it all again. Like we did.
Smith1876 is offline   Reply With Quote
Old 11-21-2021, 12:05 PM   #12
forestgirl's Avatar
2019 30' International
Battle Ground , Washington
We have this exact problem too and we called AS about it. Our bedroom window had a small leak (we have since caulked all around it and that problem is solved) but according to AS they use a black adhesive (not since 2019 which is our AS year) and if the flooring or subfloor gets moist or wet it leaches through. It is not mold. That was my fear but the black splotching is the adhesive. We are having AS repair it next spring. They only do one floor a week and the end of March was the earliest we could make the appt. The floor has since dried with no further leaching or issues so you probably want to be sure you don’t have a leak somewhere.
forestgirl is offline   Reply With Quote
Old 11-21-2021, 12:11 PM   #13
MMCMRET's Avatar
2021 25' Flying Cloud
Fredericktown , Ohio
I have seen these before, but in a house. Looks like mold stains. There is/was water somewhere for an extended period of time. A lot of great trouble shooting suggestions have been offered. We ran a dehumidifier until the source was located.
Todd Mizer
2021 25' FBT Flying Cloud
Ford F-250 6.7L
WBCCI #6826
We have Year-Round Courtesy Parking.
MMCMRET is offline   Reply With Quote
Old 11-21-2021, 01:34 PM   #14
thewarden's Avatar
2016 27' International
Sherwood Park , Alberta
No need to inspect it to know what the problem is. Vinyl flooring needs to be fairly wet underneath for a prolonged period of time before you see the evidence on top. When you see this kind of staining coming from under the flooring, it is a good bet that the plywood subfloor has been soaked for some time. It is unfortunate news, but accurate non the less.
thewarden is offline   Reply With Quote
Old 11-21-2021, 06:11 PM   #15
Hiho Silver's Avatar
2016 27' Flying Cloud
Overland Park , Kansas
Same thing happened to us. We had a stain under the Airstream mat with the rubber back. It was wet under the mat from a leak. Airstream said it was a black undercoating (adhesive) welling up from under the floor.
Hiho Silver is offline   Reply With Quote
Old 11-21-2021, 06:18 PM   #16
"Cloudsplitter"
I also made the trip and reached the same conclusion.
Old 11-22-2021, 11:05 AM   #17
David Logue's Avatar
2008 25' Safari FB SE
Allen , Texas
I had the same problem at my rear end and around the door. Water for prolonged time. Pulled up the flooring replaced decking where needed and installed new flooring.
David Logue is offline   Reply With Quote
Old 11-23-2021, 07:11 AM   #18
Update
Ok, bad news, it is water. I bought a $28 moisture meter on Amazon and it lit up like the fourth of July when I put it on the spots. Using the meter, we were able to figure out that the water is confined to one area only- surrounding the large closet next to the fridge in our 23fb layout. The water pump and regulator are both under there, and when we opened it up everything was soaked under there with multiple of the PEX tubes leaking.
Husband is a marine engineer, so luckily knows about all of this stuff. Was tinkering around with it for a while and he says he hates that PEX stuff, it's not the greatest. Good news is the subfloor is not soft, rotted, or damaged, just a little wet. We ran a mega dehumidifier all night last night near the area and it already looks very dry.
Anyways, we believe that has been the source of our leak and now we are likely looking at spending our Thanksgiving "holiday" ripping up our vinyl floors, drying out the sub-floor, and replacing vinyl. Any tips/help for that is greatly appreciated (of course we have also been scouring Youtube videos)
Thanks for the tips and Happy Thanksgiving all.
Old 11-23-2021, 07:24 AM   #19
1987 34' Limited
Hantsport , NS
I acknowledge that your pex is contributing to the leak, but while in there you may also like to consider the fridge vent.
I'm not sure how your fridge vent and chimney are configured, but on our '87 the chimney was poorly sealed at the roof seam. Water entered, ran down the inside of the wall, and pooled on the floor. This area is well hidden behind cabinets, and requires a gymnast's suppleness to get your eyes into the offending area. The fridge vent on the side wall is huge and when we get horizontal rain/high winds with rain the water blows in and pools on the floor as well. Having done our shell off I'm at a loss to decide what flooring to put over the new subfloor as I'd prefer something breathable vs waterproof. When we pulled up the old (beautiful) vinyl plank waterproof flooring it was gross underneath from trapped moisture. Having read everything that I can find on the topic here as well as the fbook A/S group, I've narrowed it down to three options: 1) don't use a glued down flooring that is waterproof; 2) use a glued down flooring that is waterproof; and 3) don't use a waterproof flooring. LOL. Lots of opinions! Cheers!
Daytonacoupe is offline   Reply With Quote
1972 airstream **look**look**look** eBay Watch Airstreams on eBay 0 07-03-2010 06:20 PM
Does this look like I will need a new Axle? kneal Axles 21 01-22-2007 05:51 PM
What does a split rim look like? tbrom Wheels, Hubs & Bearings 9 09-30-2006 05:58 PM
What does the inside look like? till Interior Restoration Forum 4 02-18-2004 09:19 PM
