Old 05-16-2021, 01:37 PM   #1
2008 28' International
Toronto , Ontario
Wet mild rotting Subfloor 2008 International
Hello,
I am replacing my floor because the vinyl floor shrunk and pulled away from the sides. I have removed it and found some wet subfloor in the rear probably from a leak on the rear storage door.
The subfloor is a little soft along the joint. Does not appear to be as bad as many of the other pictures I have seen in these forums.
I am posting a picture I am wondering if anyone has some advise on what to do about it. I am hoping I can just let it dry and move on.
ID:	395604   Click image for larger version
ID:	395606   Click image for larger version
gweston is offline   Reply With Quote
Old 05-16-2021, 02:59 PM   #2
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
Use Minwax Cure Rot on the soft spots.
https://www.amazon.com/Minwax-417000...06672892&psc=1
First and foremost find and fix the leak.
Old 05-16-2021, 04:56 PM   #3
Toronto , Ontario
Thanks! I believe I have the leaks sorted. Is there any need to epoxy seal the floor? I am hoping not because I would like to put in a new floor this weekend while I have help.
"Winterize" in a mild Climate bennu36 Sprinter and B-van Forum 47 11-19-2013 07:05 PM
Mild Electrical Buzz (shock?) LavenderMoon Electrical - Systems, Generators, Batteries & Solar 9 07-22-2013 06:33 PM
airstream trailer frames rotting out william Haym Repairing/Replacing Floor &/or Frame 2 07-12-2006 12:33 PM
Seen rotting in a field... Sneakinup Off Topic Forum 2 04-13-2004 07:39 PM
Interior Drapes rotting-out, Argosy M20 TinCanSue Upholstery, Blinds, Walls & Interior Finishes 8 02-02-2003 04:14 PM
