Old 02-18-2017, 09:06 AM   #1
Houston , Texas
Vintage AS frame repair suggestions?
I have a 1969 Safari 23'. I wasn't planning to go this far down in the renovation process, but everytime I peeled away one layer of the onion, another presented itself that also needed attention. Anyway, now I'm down to the outer shell and the subfloor and it is apparent the frame needs repair. I know of at least one place where the floor was rotting and when I pulled it up, discovered the frame had rotted out in that spot and had been replaced with a piece of 1x4 pine! I'm looking for suggestions on who to take it to for repair. I would also like to go ahead and replace the axel based on other information I've read on the forum. I am in Houston, Texas. Any suggestions would be appriated.
TrvlingrlTx is offline   Reply With Quote
Old 02-18-2017, 09:44 AM   #2
DaveMc's Avatar
2005 30' Safari
Montgomery , Texas
I've seen a guy in (I think) New Braunfels who does vintage restoration. Found him on Google. Bob Jones RV in South Houston may, not sure on the vintage part. I don't have experience with vintage restoration, those who do may be able to guide you to someone non RV specific that could do the welding if you know what to tell them you need and where. Good luck and post pictures-- we all love to see what things look like!
DaveMc is offline   Reply With Quote
Old 02-18-2017, 11:04 AM   #3
1959 22' Flying Cloud
Escondido , California
FWIW, if you can't find an experienced Airstream person you can try classic car restoration companies. Sometimes the smaller shops don't mind doing this kind of work since they do lots of frame repair along with axle installs. Also, since it's a vintage model it's what they like.
If you do a complete shell off job they can blast the frame and paint it too.
"On a vintage Airstream if it aint absolutely broke DON'T TOUCH IT!!"
2bkidfree is offline   Reply With Quote
Old 02-18-2017, 11:14 AM   #4
1966 22' Safari
Fredericksburg , Texas
I just finished our 1955 chassis rebuild. The way I did it was to purchase some 14 gauge purlins from a local steel supplier like Metal Mart or Triple S Steel. Any welding shop can weld the new members back where the old ones were. Since I'm not a good welder, I let the professionals do the welding. Since the 'C' channel has a lip that could hold moisture, I drilled some weep holes in the bottom. Can it be safely transported to a shop? There are a lot of AS owners living in and around Houston that may be a source for good information.
Bubba L is offline   Reply With Quote
Old 02-18-2017, 01:19 PM   #5
1967 26' Overlander
Spartanburg , South Carolina
For vintage work, it is a good idea to join the Vintage intra club of the Wally Byam Airstream Club, aka WBCCI. The vintage folks have mostly been through everything possible with the old airstreams and are usually willing to impart information just for the asking. In only costs $95 per year for WBCCI and $20 py for the Vintage club.
Jacob D is offline   Reply With Quote
Old 02-18-2017, 06:47 PM   #6
1978 Argosy Minuet 6.7 Metre
1971 27' Overlander
1973 31' Sovereign
Griffin , Georgia
Images: 14
I'm rebuilding a '71 Overlander Putting her back together... wooHoo!, I took Dixie to a welding shop after I had removed the bad spots in the sub floor. Added a grey water tank while I was at it, and had the welder add in supports for it
Good luck ��
It's soooo worth it!
paddle whisp is offline   Reply With Quote
Old 02-19-2017, 05:43 PM   #7
crestonrv's Avatar
1948 16' Wee Wind
1964 26' Overlander
2007 19' Bambi
crossville , Tennessee
pull belly and do full inspection so u know whats there .
we are far away but seems mark at airstreamguy.com is within striking distance of u
crestonrv is offline   Reply With Quote
Spray Paint for Frame - Suggestions ericpeltier Repairing/Replacing Floor &/or Frame 12 08-22-2016 09:47 PM
Scrape crunch rip, ouch, parking accident, repair suggestions? jacarape General Repair Forum 12 12-16-2008 10:04 AM
shop repair of 1970s rear frame separation (non elephant ears repair) RV shop review simonhanbury Repairing/Replacing Floor &/or Frame 49 06-24-2008 10:16 AM
Awning Repair - Need Suggestions. lebolewis Awnings 6 08-12-2007 11:38 AM
Frame Repair or New Frame muddy_hollow Brakes & Brake Controllers 14 09-26-2006 06:55 PM
