Old 06-15-2019, 12:35 AM   #261
jcarp sculptor
1966 22' Safari
portland , Oregon
Ready to install new sub floor but dont have old pattern to cut from....
Does anyone have a curved pattern cut for 66 safari they can send?????
I am in Portland Oregon..... never done anything like this.....
Anyone in the community that has the curve pattern for 66 safari subfloor?
suggestions on how to proceed.????
jCarp
jcarp is offline   Reply With Quote
Old 06-15-2019, 06:00 AM   #262
1966 22' Safari
Fredericksburg , Texas
jCarp
jcarp, you may get better results if you start a separate thread on the subject. Ours is 22.5 radius. Let me know if you need more since they all vary. Good luck
Bubba L is online now   Reply With Quote
Old 06-16-2019, 11:42 AM   #263
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
The old faucet is now leak free. 😁
I ended up using a couple of inches, maybe less of the fat kind of graphite & oil impregnated string..from Ace. Not the rubbery stuff.
Used a dental tool to push it down flush into the fixture.
Then I had some beveled yellow rubber washers. Those I drilled out to fit the valve shaft.... Extreme press fit.
The washers were pushed down over the shaft then the nut snugged down.
Thanks for the tips.....
Happy Sunday.
Dingo Girl is offline   Reply With Quote
Old 06-16-2019, 06:53 PM   #264
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Yea! Clap, clap, clap. There is nothing like being leak free. David
WBCCI #8607
VAC Region 11
Link to my 1975 Overlander Improvement Journal:
https://www.airforums.com/forums/f17...ml#post2053792
Link to our 1976 Renovation Project:
https://www.airforums.com/forums/f221...ct-202081.html
Old 06-21-2019, 04:12 AM   #265
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
Anybody going to be in Michigan at the Tincan tourist rally at the Interlochen State Park?
Old 06-21-2019, 04:13 AM   #266
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
This weekend.
Old 07-09-2019, 10:28 AM   #267
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
Why when i attach my TV to the trailer the lock lever for the ball wants to stick up?
Are there different tow balls in 2"?
Old 07-09-2019, 07:30 PM   #268
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Boy, not that I'm aware of. I'd recommend removing the sliding shoe and insure it is positioned right. It is supposed to slid down and out of the way when you drop the trailer on the ball. If it is being pushed up, something is wrong.
Others will chime in and have a solution to the problem.
David
WBCCI #8607
VAC Region 11
Old 07-10-2019, 03:33 AM   #269
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
The shoe is a replacement from vintage trailer supply. Supposed to be for my vintage.
The shoe slides up & out of the way.
The traiker drops on the ball nicely.
The shoe when down around the ball is beyond the half way point of the ball but should be down closer to the neck of the ball. I think.
I even tried it with just the ball, same thing. That rod the shoe is attached to sticks up out of the tongue about an inch. The handle instead of being flat when closed is at about a 45 degree angle.
I'll get a picture tonight and post.
I'm kind of scared to tow it like that.
Just when I'm almost done. 🤔
Old 07-10-2019, 07:37 PM   #270
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
I wonder. I believe there are more than one manufacturer of the stamped A-frame ball receiver. There might be differences between this brand and that brand. It might be VTS provided one shoe when you might have needed a different brand. I'm reaching here, but I seem to recall a discussion thread on that subject from maybe 7 years ago or so. Search AirForums.
I believe the manufacturer of your ball receiver stamping will be stamped in the piece somewhere. Maybe under layers of paint.
David
WBCCI #8607
VAC Region 11
Old 07-11-2019, 03:45 AM   #271
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
Paint is gone. & repainted. Its a Marvel 2"
Our local RV dealer sold me the ball.
I didn't get to the garage last night we had humidity that drove me inside after a day of working in it.
I'll try tonight for a picture.
Old 07-11-2019, 03:17 PM   #272
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
Old 07-11-2019, 03:20 PM   #273
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
This photo showing the rod standing proud is with the ball clamped in the receiver.
Old 07-12-2019, 01:00 PM   #274
Central , Mississippi
Here are photos of the 2 Marvel latches that I have. I have not rebuilt them but the first needs attention. The release lever does not lift high enough to let go of the ball, I have to grab and pull up to get it to let go.
ID:	346231   Click image for larger version
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie(RIP) -
A honkin' long 34' named AlumaTherapy https://www.airforums.com/forums/f20...num-54749.html
and a 26' '63 Overlander, Dolly https://www.airforums.com/forums/f10...ome-71609.html
Old 07-13-2019, 04:11 AM   #275
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
Thanks for the pictures.
Mine will hold the ball just fine. & it let go of it fine. I want to figure out why the rod stays partially up.
I've taken the latch off the tongue & nothing appears to e wrong. Or missing.
Old 07-13-2019, 05:08 AM   #276
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
I just found the old latch i took out several years ago. I am going to put that back in and see what happens.
+ compare the 2 side by side since it's been several years ago i replaced it.
Old 07-13-2019, 11:56 AM   #277
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
The 2 latch assemblies are the same.
I put the old one back in and the latch handle snapped down flat. There was no front to back or side to side slop but there was some up & down slop.
I put the new assembly back in & zero slop when the ball is locked in. But the rod still sticks up like in the picture.
I'm stumped.
Old 07-21-2019, 05:20 AM   #278
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
Any suggestions on a battery monitor that doesn't take an electrical engineer to install?
Old 07-21-2019, 06:38 AM   #279
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
My Caravel bathroom is 99.9% done. All that's left is to press the window shade. 😊
The only thing left to be able to call the camper "done" is put in the water heater.
10 years and God only knows how many hours later..............
Old 07-21-2019, 07:43 AM   #280
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
I should add that the last 5 years were the major renovation years. The first five were little stuff while I got up the courage to do the floor.
Floor, frame, all major systems etc......
Today is the day! DJCJ 76 AIR Member Introductions 12 07-20-2010 12:18 PM
RV Story in USA Today--Today SteSpot On The Road... 0 05-18-2009 02:14 PM
Today's today, You know what that means? codybear Off Topic Forum 20 11-08-2006 11:31 PM
South Today's the day for generator questions Minnie's Mate Boondocking 15 11-01-2006 06:11 AM
today's the day! bradk Our Community 31 04-21-2006 08:28 PM
