Old 07-23-2018, 08:34 PM   #241
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Got it! Thanks!
Old 07-28-2018, 08:16 PM   #242
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
Originally Posted by Dingo Girl View Post
Tested them, water surely does flow down hill. ;-)
Next up is finish up the toilet perch & the bath sink/cabinet.
Then formica the counter tops install & done!
I'm sure I'm forgetting something but it's getting very close.
Battery install too. Waiting till the very end to buy that.
Thanks for the kind words David.
Let me add the propane system to the list.
That is next. I got an aluminum tank. 30#. It had 2 thirty pound steel tanks before.
Any tips on a single tank system are appreciated.
This certainly has been a learning experience.
Dingo Girl is offline   Reply With Quote
Old 07-29-2018, 06:47 AM   #243
Joyflea's Avatar
1967 26' Overlander
Alpine , Texas
Just finished reading your whole tread . Amazing work ! Good documentation. Keep up the good work . Blue
Joyflea is offline   Reply With Quote
Old 07-29-2018, 12:31 PM   #244
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
Thank you! It's not going fast but it's going....
Old 07-29-2018, 07:13 PM   #245
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Nothing wrong with a single tank system. The plumbing is the same except you won't need a "switch over valve". You will have to manage the level in the single tank so you don't run out on a cold Michigan winter night and have no heat.
David
WBCCI #8607
VAC Region 11
Link to my 1975 Overlander Improvement Journal:
https://www.airforums.com/forums/f17...ml#post2053792
Link to our 1976 Renovation Project:
https://www.airforums.com/forums/f221...ct-202081.html
Old 04-10-2019, 02:33 PM   #246
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
This is how my new Dometic toilet arrived. The porcelain chunk that is gone was NOT in the box.
Box had original tape and no damage to it at all.
I can't imagine how that got out of the factory.
Old 04-10-2019, 07:41 PM   #247
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Well hello again. You must have thawed out after a rather long winter. Nice to see your post on a not so nice subject.
My new Thetford Bravura toilet won't hold water in the bowl. The blade valve seal must be damaged or defective. And I'm unsure how to get a replacement seal. The dealer can't seem to find the right part number. It appears you gotta buy the whole darn mechanism that opens the slide valve to get the seal. Seems too dumb for words. I'm probably missing something.
Likely a human error in the factory judging from your description. They will likely replace it for you. Hassle anyway.
David
WBCCI #8607
VAC Region 11
Old 04-11-2019, 03:01 AM   #248
W , New England
Originally Posted by dbj216 View Post
...snip...
Iím not sure what the Bravura looks like, but whatever model I have stopped holding water after a couple years and I learned in the forums about sealing the blade valve with dialectic grease. Rubber gloved up, I used a toothpick to clean the inside of the rubber seal where the blade rests when closed (goes without saying you want to wipe that toothpick real good before using on your teeth - no, Iím TOTALLY kidding ) and then apply a liberal amount of the grease to the blade and the seal. Open and close the valve a couple times and it sets quite well. Now part of my winterization process every year.
If applicable to yours, give it a try. Good luck!
Old 04-11-2019, 06:17 PM   #249
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Thanks for the tip. I have tried silicone lube. But I will try some of the grease and maybe it will seal up.
David
WBCCI #8607
VAC Region 11
Old 05-28-2019, 07:38 AM   #250
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
Lifeline battery installed, everything working. Oh happy day.
Old 05-30-2019, 06:38 PM   #251
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
How can it be that everything is working? That never happens to me.
Lifeline is a very good battery according to the reviews on it. It should last a very long time.
David
WBCCI #8607
VAC Region 11
Old 06-10-2019, 03:32 PM   #252
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
David
David do you know the secret for wrapping an old faucet stem with packing string & having it not leak out around the handles when they are "open".?
I bet I've done it a dozen times & can't quite get it.
Old 06-10-2019, 04:30 PM   #253
Joyflea's Avatar
1967 26' Overlander
Alpine , Texas
Make sure the string still has a good coat of wax or grease on it . After packing the nut as it is tightened squeezes down and makes the seal . Make sure the shaft is smooth . Good luck .
Old 06-11-2019, 07:39 AM   #254
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
I'll give it a go tonight, thank you Joyflea!
Old 06-11-2019, 10:39 AM   #255
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
You can buy a teflon "string" at Lowe's and Home Depot, that is specifically designed for this application. I've used it to repair outdoor faucets, and it was quite effective and painless.
good luck!
Belegedhel is online now   Reply With Quote
Old 06-11-2019, 07:25 PM   #256
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Gee, I've never used a packing string. My old faucets have what looks like a cork sleeve that fits around the stem. Then I tighten the packing nut so I don't get too much drag when opening the faucet.
Or I just replace the whole faucet with a new one.
David
WBCCI #8607
VAC Region 11
Old 06-12-2019, 03:50 AM   #257
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
I think the teflon string was the rubbery messy stuff.
Went to our local plumbing supplier & they were out of the packing string.
I'll try ACE tonight.
David i just can get a new faucet. The old shower faucet is too cool to let go.
Old 06-13-2019, 05:14 PM   #258
Central , Mississippi
Today is the day.
I tried the various strings without much luck. I gave up and used a cone shaped rubber seal and finally got the old faucet to seal. I think mine might be missing a washer to compress the new string
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie(RIP) -
A honkin' long 34' named AlumaTherapy https://www.airforums.com/forums/f20...num-54749.html
and a 26' '63 Overlander, Dolly https://www.airforums.com/forums/f10...ome-71609.html
Old 06-14-2019, 03:33 AM   #259
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
Does your faucet have a dome shaped packing nut?
Mine does & I'm beginning to wonder if that is the problem.
I've read the domed shaped nuts require a dome shaped washer.
I'll work at it this weekend.
Thanks!
Old 06-14-2019, 08:03 PM   #260
Thanks!
Geez, a test I didn't study for. I had a dream last night I was back in history class and I had an exam I forgot to study for also.
If I recall, the nuts were an inverted cone on the back and the packing rope simply jammed between it and the shafts jack screws. Mechanically it didn't make sense and I wrote it off a prior owner fixes. If I tightened the nut to the point of not leaking, the valve wouldn't open much for flow. I suspect the assembly should have been nut, gland string, washer, fixture all fitted over the shaft. Without the washer nothing would seal.
Today is the day! DJCJ 76 AIR Member Introductions 12 07-20-2010 12:18 PM
RV Story in USA Today--Today SteSpot On The Road... 0 05-18-2009 02:14 PM
Today's today, You know what that means? codybear Off Topic Forum 20 11-08-2006 11:31 PM
South Today's the day for generator questions Minnie's Mate Boondocking 15 11-01-2006 06:11 AM
today's the day! bradk Our Community 31 04-21-2006 08:28 PM
