Old 03-04-2021, 03:15 PM   #1
1969 23' Safari
Troutdale , Oregon
Subfloor radius the same front and rear?
I have a 1969 Safari that I am renovating. Getting ready to cut the new subfloor to fit on the chassis I built.
I am wondering if the front and rear radius is the same? The old subfloor was patched together in the front, a majority not under c-channel and so I don’t have a good template for it. The rear piece of flooring is fairly intact although rotted and I was thinking of using this as a template for both.
Vilnutz is offline   Reply With Quote
Old 03-04-2021, 03:19 PM   #2
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Not necessarily. I would make a template out of heavy kraft or rosen paper to make sure before cutting the subfloor wood. If the body is separated from the chassis, can you set it down on the paper to template?
Shari
RMVAC | WBCCI DenCO Unit | BIRDY - our 1956 Safari | 1964 Serro Scotty
Old 03-04-2021, 07:38 PM   #3
1969 23' Safari
Troutdale , Oregon
Shari
Thanks. I kinda figured, but thought I’d ask just the same. Unfortunately, the shell has side wraps in the aluminum that won’t let it sit flat on anything. I might have to wrap something around the base on the outside of the shell.
Old 03-04-2021, 10:19 PM   #4
batman's Avatar
1964 22' Safari
modesto , California
Nope the radius's are different.
It would be ideal to use the old sub-floor as your template. However if it is gone. You can make templates from the inside dimension using corrugated or cardboard stock, I have even used thin ply veneer. Then transfer to your new wood.
-Dennis
batman is offline   Reply With Quote
Old 03-06-2021, 06:57 AM   #5
Albuquerque , New Mexico
I can't speak to the front vs. rear similarity, but I do know that the original subfloor in my '69 Safari is/was significantly undercut in several places. The original subfloor was cut too short making the c-channel sit on a slim section that jacks my ability to properly secure it. The c-channel itself is a better template than the original subfloor--if that is still attached to the trailer, make paper/cardboard template from it.
matt.
Matt0k0 is offline   Reply With Quote
Old 03-07-2021, 07:34 AM   #6
1969 23' Safari
Troutdale , Oregon
I went with a cardboard template of the c-channel which seems to have gone well. Obviously the real test will be when I mate up the shell. Thanks for the help, folks.
Andrew
Interior wall - ribs at the front and back radius of trailer kriskari4315 Ribs, Skins & Rivets 3 05-01-2019 06:55 PM
Replacing front and Rear Subfloor on 1981 Excella Rear Bath carnoldnyc3 Repairing/Replacing Floor &/or Frame 3 02-01-2017 04:55 PM
Same old, same old whitegs Tow Vehicles 36 08-11-2016 03:22 PM
How is this possible, same manf, almost same frame, diff GVWR carl2591 Tow Vehicles 7 07-15-2014 07:23 PM
Tips on backing up and Turning radius NewStreamer On The Road... 36 08-12-2006 08:27 PM
