Old 09-28-2020, 06:54 PM   #1
waninae39's Avatar
2017 22' Sport
NCR , Ontario
Squeaky floor in one spot
Our 4 year old sport 22fb now has a very noisy squeak in one spot.
It is on the right side of the fridge, left side of the uwave
It seems to be located close to the top of the road side wheel.
Anyone else seen thus?
Any means to determine the cause?
Any solutions?
waninae39 is online now   Reply With Quote
Old 09-29-2020, 07:22 AM   #2
Trilla the Traveling Tube
kpfate's Avatar
2018 22' Sport
CHEYENNE , WY
Have you checked all of the doors (cabinet) as well as tightened all of the screws in each? These do come loose over time and need a tightening every now and then.
As Fate would have it
2018 GMC Sierra 1500
2018 22FB Sport
kpfate is offline   Reply With Quote
Old 09-29-2020, 07:39 AM   #3
waninae39's Avatar
2017 22' Sport
NCR , Ontario
Yes, I did that first
Old 09-29-2020, 07:52 AM   #4
DonRich7878's Avatar
2013 30' Classic
Key West , Florida
Any solutions?
A squeaky floor above fresh water or holding tanks can be caused by inadvertent tank pressurization, caused either by over filling of fresh water or improper tank flushing. The thin walled plastic tank expands up, pushing the floor and loosening the fasteners. Once the pressure is released, the damaged floor area then flexes when walked on and often squeaks.
DonRich7878 is offline   Reply With Quote
Old 09-29-2020, 09:49 AM   #5
2016 26' Flying Cloud
Spring Lake , Michigan
We have a squeak in our 2016, 26u. The holding tank theory is interesting. Should be easy to verify if the squeaks go away when tanks are full.
happy2retire is offline   Reply With Quote
Old 09-29-2020, 11:53 AM   #6
BoscoMN's Avatar
2015 19' Flying Cloud
2017 25' Flying Cloud
Rosemount , Minnesota
Our 2 year old 2017 (FC rear bed unit) was squeak free. Then the shower wand fixture developed a slight leak in the wall and I saw water leaking out of the floor/wall junction. I got it fixed by cutting an access port in the wall to get to the pipe fitting. About a couple of months after that, the floor near the leak developed a squeak that will not go away (the walkway between the wall and the bed). Nothing structural as it was not a lot of water - the floor boards are all solid. If you have a water leak from the refrigerator or plumbing that gets the floor wet, that could cause a squeak.
2018 F-250 6.2L Gas
Blue Ox SwayPro 1000#
BoscoMN is offline   Reply With Quote
Old 09-30-2020, 09:35 AM   #7
bolerama's Avatar
2017 30' Flying Cloud
2008 23' International
Keremeos , British Columbia
Images: 30
We had a squeak in our 2017 when it was new and we had noticed the squeak in other new trailers we had viewed. In our 2017, it was an easy fix and not related to any water damage. The trim where the floor and wall meet needs to be tightened. There are screws. The dealer fixed this for us when we bought it and it hasnít squeaked since. Try this simple solution.
Lisa
bolerama is offline   Reply With Quote
Old 09-30-2020, 01:53 PM   #8
Annapolis , Maryland
squeaky floor
Our floor started squeaking between the shower and head doors (2017 27FCFBT). We also had water leaking from the shower (somewhere) that discolored the floor. Not sure if the water caused the squeak.
Since this was under warranty, we had JC do the repairs. They replaced the floor and reinforced the floor frame/joist between the shower and head (apparently this can be a weak point).
The squeak has not re-appeared.
rhpeahl is offline   Reply With Quote
Old 10-01-2020, 07:34 AM   #9
Mikebrady62's Avatar
2019 27' International
Rogers , Arkansas
Our 2019 27' has a squeaky floor by the refrigerator when the stabilizers are not in use. Once the stabilizers are down the squeak goes away.
Mikebrady62 is offline   Reply With Quote
50% off - SPOT Satellite Messenger and SPOT Trace Adventure.AS Electronics & Connectivity 0 04-23-2019 11:12 AM
Squeaky floor dfschultz Repairing/Replacing Floor &/or Frame 3 07-05-2015 01:54 PM
Squeaky bathroom floor oceanair Floor Finishes 0 06-20-2009 09:35 AM
Squeaky Floor straya General Repair Forum 5 03-04-2009 12:16 AM
squeaky floor clintn 2005 and newer - Bambi all models 2 04-18-2007 10:17 PM
