09-05-2010, 08:17 AM
#561
1971 21' Globetrotter
Arvada
The one I looked up was over 700 bucks, I'll look again
09-07-2010, 05:59 PM
#562
1955 22' Safari
Great Lake State
Started working on the cabinets over the weekend.
toastie
09-08-2010, 06:28 PM
#563
1955 22' Safari
Great Lake State
Redesigning the shower and going back to my original design of using a removable teak flooring. Lowered the drain by over 2 inches by going with different fittings to make it work, should be much cheaper then going with the stainless steel.
toastie
09-09-2010, 05:28 PM
#564
1973 31' Sovereign
Portland
, Oregon
Here is one for $278 that looks pretty nice.
RV Adjustable Table Legs,Gas Powered Pedestals
These folks seem to have a lot of interesting furniture and other accessory items too.
Malcolm
Only he who attempts the ridiculous can achieve the impossble.
09-09-2010, 05:45 PM
#565
1976 25' Tradewind
, Maine to Arizona
Airstreams Are Not Cheap
I like Toastie's practical approach.
Costs are skyrocketing everywhere, any way to save a few bucks on a very expensive hobby.
$90 vs gas powered, $278 plus shipping and I do not see a starter button to get it running, kick start?
"Talk is cheap, Airstreams are expensive," Wally Byam.
25' Tradewind
'18 Promaster 1500 High Roof
09-18-2010, 07:10 PM
#566
1955 22' Safari
Great Lake State
09-20-2010, 12:15 PM
#567
1956 22' Flying Cloud
Dallas
Toastie, what did you use for (and how did you install whatever you used) the curved joint between the shower wall and the interior wall of the coach (in the picture on the left in your post 566)?
Congratulations on the great progress you have made.
09-20-2010, 04:41 PM
#568
1955 22' Safari
Great Lake State
Thanks hjairf....For the inside curve wall I went with Stabilit, .090 in. FRP Wall Panel at $25.00 a sheet, seems to be great stuff, cut's great with saber saw and is very flexible. Come's in a assortment of color's and also end caps, division bar, etc. I used small rivets for the end, what you see in the picture, and large head rivets for the large sheet, I used 6, doesn't take many. It a 2 person job, one just to help steady the piece while you pre drill and rivet. The bathroom/shower will be 60" long. Hope this help.............toastie
Stabilit .090 in. FRP Wall Panel 4 ft. x 8 ft. - White - MFTF12IXA480009600 at The Home Depot
Search Results for frp at The Home Depot
10-02-2010, 05:43 PM
#569
1955 22' Safari
Great Lake State
Finished the ruff-in of the shower walls and vanity then disassembled, will finish in the basement over winter and reassemble in the spring. Getting ready to finish compounding then polish the interior.............toastie
10-08-2010, 02:41 PM
#570
1955 22' Safari
Great Lake State
Will compound 2 more time, (1) compound with wool pad (2) compound with cyclo with fleece wraps. Then polish with cyclo with fleece wraps...........toastie
10-10-2010, 12:48 PM
#571
1955 22' Safari
Great Lake State
Added waste hose carrier today...........toastie
10-10-2010, 02:25 PM
#572
Sioux Falls
, South Dakota
Looks nice. It's all looking like a first class job.
Gary
10-10-2010, 04:33 PM
#573
1955 22' Safari
Great Lake State
Gary
Thanks very much, getting to the fun part now.............toastie
10-10-2010, 04:37 PM
#574
1955 22' Safari
Great Lake State
Had a great find on a rare 1947 Spartan door handle..........toastie
10-10-2010, 05:43 PM
#575
Port Hadlock
That is a really great looking handle, Toastie!
I had a set of those waste hose castings arrive in the mail a couple of days ago. They're pretty nice.
10-11-2010, 05:59 PM
#576
1955 22' Safari
Great Lake State
Thanks Steve,
If you received the same castings that I did, the thin wall pvc from Home Depot or Lowes will not work, the inner dia is to small, there is a thinner wall that you will need. I found the thinner wall at Tractor Trailer supplies and still had to modify the hose connection just a little to make it work, I really like the set up................toastie
10-15-2010, 09:01 AM
#577
1973 31' Excella 500
Spring Green
, Wisconsin
toastie,
I've read your entire thread over the past couple days. It was like reading a good novel.
Thank you for taking the time to share so many pictures, products, resources and so much valuable information.
Your trailer is amazing!! Keep up the good work.
Lew TAC #WI-6
Nobody can help everybody, but everybody can help somebody.
10-15-2010, 09:44 AM
#578
Port Hadlock
Originally Posted by toastie
Thanks Steve,
Thanks, toastie. That'll save me from some errors I'm sure.
10-19-2010, 05:30 PM
#579
1955 22' Safari
Great Lake State
Originally Posted by driftless
toastie,
thanks very much.............toastie
10-19-2010, 05:40 PM
#580
1955 22' Safari
Great Lake State
Added Bal 24002D 7500lb per jack heavy-duty steel scissor jacks designed for RV's. They bolt on the frame with large lag screws, and can lift the trailer to level if necessary. They tuck up out of sight unless you look directly under the trailer, they do run up and down quickly with a socket on the end of a cordless drill.
I could actually raise the wheel up off the ground using the two jacks on one side convienient for changing a tire.
toastie
