05-11-2010, 02:57 PM
#461
1955 22' Safari
Great Lake State
I also ask Tremco how do you read the dates on the tube's and this was there reply:
on the plunger or on the case, it will be a letter / number, i.e. A/10 would be Jan of 2010.
Sealants Green Road Customer Service
Tremco Commercial Sealants & Waterproofing
3735 Green Road
Beachwood, Ohio 44122
1-800-321-7906 (toll free)
1-216-292-5036 (fax)
tscs@tremcoinc.com (email)
05-31-2010, 10:51 AM
#462
1955 22' Safari
Great Lake State
Finished the belly pan today except for around the tanks, that will be the very last thing that I do, probably will do some local camping before closing off to test for leaks. I used 5052 0.04" on all of the belly pan, will go with 0.032 on the next restoration.
toastie
05-31-2010, 11:21 AM
#463
Port Hadlock
When you have a belly pan that looks that good, you really should have a way of turning the trailer over, so people can see it.
06-03-2010, 11:56 AM
#464
1967 28' Ambassador
1963 19' Globetrotter
1970 29' Ambassador
Waukesha
, Wisconsin
Looks great!
What made you decide on .040"? My understanding is that .025" is the stuff to use for belly pan material.
06-03-2010, 03:35 PM
#465
1955 22' Safari
Great Lake State
Originally Posted by byamcaravanner
Looks great!
Thanks, the suppler is very close to the house and all he had was 0.040 at a good price. 5052-H32 has the highest strength in the NON-heatable alloys, has higher fatigue strength than most alloys, excellent corrosion resistance, and has excellent workability.
toastie
06-03-2010, 03:38 PM
#466
Jupiter
My .040 choice was sealed by 60 inch widths...
The days are short and the night is long and the stars go tumbling by.. . ~Airstream~
06-06-2010, 06:47 AM
#467
1955 22' Safari
Great Lake State
Originally Posted by malconium
That is a very interesting approach to mounting your water heater. I hope the exhaust isn't hot enough to melt the paint on your license plate. Will you be mounting it a little away from the body?
Malcolm
Malcolm
Since my hot water operates on both gas or electricity and after talking to friends that have the same heater decided to go only electric.
toastie
06-07-2010, 08:23 PM
#468
1962 22' Safari
2016 30' Classic
Southeast
, Michigan
toastie
Excellent work!!! Did you make those end belly wraps using the originals as templates or free hand from scratch? I am going to need to make new end belly wraps fr my '55 Safari and don't have complete pieces to work from as templates. It is a bit intimidating, but if you got those that nice without templates I will be more encouraged that I can do something almost as nice.
Joe
WBCCI/VAC #702 & #6768
06-08-2010, 06:29 PM
#469
1955 22' Safari
Great Lake State
Thanks Joe, yes, I used the old templates as a very rough guide, highly recommend electrical shears as shown in the below picture for fine tuning cuts.
14 Gauge Swivel Head Shears
toastie
06-08-2010, 07:33 PM
#470
1962 22' Safari
2016 30' Classic
Southeast
, Michigan
I am hoping to get ready to start replacing exterior panels and bellypan on my '55 Safari during our July shutdown. I might be interested in borrowing your "templates" if they have not been thrown away (not sure how usable the remaining pieces on my trailer might be). I might also like to talk to you about how you did your bellypan replacement. I can't remember - did you also replace some exterior skins? If so, I might like to talk to you about that too.
Great work!
Joe
06-08-2010, 08:30 PM
#471
1955 22' Safari
Great Lake State
Great work!
Sorry Joe but all of the old belly pan has been trashed, not replacing any of the outside panels.
toastie
06-12-2010, 08:36 AM
#472
1955 22' Safari
Great Lake State
FanTastic fan
Replaced the front Hehr vent with a new FanTastic fan from http://www.vintagetrailersupply.com/Fan_Tastic_Fan_p/vts-414.htm and from a distance you can't tell the difference. The 55 year old sealant was in very bad shape, had to be a source of leaks, will be replacing the other 2 vents.
toastie
06-12-2010, 08:42 AM
#473
Baltimore
, Maryland
Toastie, you are all about stealth when adding the modern into the vintage... I have been told that the original Herh cover fits over the fantastic cover. I have not tried it yet, but saw it on this forum.
06-12-2010, 08:48 AM
#474
Port Hadlock
It's easy.
06-13-2010, 03:17 AM
#475
1951 21' Flying Cloud
1960 24' Tradewind
Folsom
Looks good.
I'm about to do the same and have read install threads where they used the closed cell foam gasket that came with the fan and threads that say they didn't (and shouldn't) (and of course the factory says you should). What was your method?
MarkR
Aluminumbskull with Led Balloon in Drag
Birch Plywood and Aluminum go together like
Peanut Butter and Chocolate
06-13-2010, 04:39 AM
#476
1955 22' Safari
Great Lake State
Originally Posted by MarkR
Looks good.
MarkR
Thanks MarkR
I saw no need to use the foam or there screws, used Olympic Bulb-Tite Rivets. I was very liberal with the trempro 635, used paint thinner to clean up the excess trempro.
toastie
06-13-2010, 06:05 AM
#477
1955 22' Safari
Great Lake State
Frank
The central air will be a challenge. Yes, the old Hehr cover will fit over the Fantastic cover, but in my case will just add a good coat of wax to the Fantastic cover every year. To keep that old Hehr cover looking good would require compounding and I just don't know if the Fantastic can handle the torque from the compounding.
http://www.airforums.com/forums/f91/...tml#post364550
Fantastic Hehr Vent- How To - Photo Gallery
toastie
06-13-2010, 11:50 AM
#478
1955 22' Safari
Great Lake State
Painted the floor and will finish putting the rest of the interior panels up, polish to mirror finish, then a second coat of paint.
toastie
06-13-2010, 03:52 PM
#479
1950 Flying Cloud 7039
1950 21' Flying Cloud
Allen
.......interior panels up, polish to mirror finish.....
toastie
You going into the traveling tanning bed business?
06-13-2010, 05:35 PM
#480
1955 22' Safari
Great Lake State
WOW...thats a great idea, twin tanning beds...............
