11-21-2009, 10:27 AM
#381
1955 22' Safari
Great Lake State
Working on putting the front trim piece on today. I learned a little trick, you can see the gap in the picture, what I did was to take the palm of my hand and layed it on top of the gap and then slowly, very slowly bend the piece back to take the gap out, then slowly worked myself around with the trim piece.
toastie
11-21-2009, 11:39 AM
#382
1972 31' Sovereign
Lexington
Is that new trim pieces? Inquiring minds and all that.....
11-21-2009, 05:53 PM
#383
1955 22' Safari
Great Lake State
No, its original...........toastie
11-22-2009, 04:27 PM
#384
1955 22' Safari
Great Lake State
Before permanently setting the front trim piece, added Trempro 635 to the outside and after setting the trim piece sealed the inside.
toastie
11-22-2009, 05:26 PM
#385
1954 25' Cruiser
Cruisin
, Wisconsin
Looking great Toastie
11-22-2009, 05:33 PM
#386
1963 22' Safari
2020 27' Globetrotter
State of
thats a great idea to stop water at each layer. I was surprised how many seams on ours weren't factory sealed (which I think led to most of the floor rot). Every horizontal, overlapped seam was not sealed, only end cap and verticle seams. Every one of them leaked. Made panel replacement easier (man that black stuff is hard to remove) though. Boy your belt trim is in great shape.
Scott & Megan
VAC LIBRARIAN WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
12-12-2009, 09:19 AM
#387
1955 22' Safari
Great Lake State
Decided to go with a inline Hygienic Self Sealing Waste Valves, has been approved for RV use in the US since early 2007. Dry sealing valve prevents the escape of odors from your waste system into your RV and eliminates the need for check vents. Can be used in a vertical application as well as horizontal. A couple of Class A builders are using them under kitchen sinks to allow for drawers below the sink.
toastie
12-12-2009, 11:44 AM
#388
1955 22' Safari
Great Lake State
12-12-2009, 02:40 PM
#390
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View
help to see pics
I really want to see some of your Pictures....from the 2008 range...on the door and windows. I get blank pages...GEF.2x2... Not JPEG. On the later pics that are JPEG it comes thru. Have we got a computer whizz available? Can I get these to show? I think your work is super and I'd like to use it as a guide in my next project.
12-15-2009, 04:34 PM
#391
1973 31' Sovereign
Portland
, Oregon
No vents needed?
These dry valves look pretty interesting and I am at the stage in my remodel where I am just about to re-plumb my entire drain system. I have a couple of questions about these valves as follows:
I can see that using these dry valves would eliminate the need for p-traps on the shower and the sinks in the kitchen and bath. I can also see that it eliminates the need for vents on the drains themselves. Is the need for additional venting on the gray water tank then completely eliminated?
Presumably I still need a vent on my black water tank since there is no p-trap on the toilet that I can replace with one of these gadgets. Is that a given?
Malcolm
Only he who attempts the ridiculous can achieve the impossble.
12-15-2009, 05:31 PM
#392
1950 Flying Cloud 7039
1950 21' Flying Cloud
Allen
Tums
Would you not need a vent to relieve the build up of gas? If the the tank is "sealed", then I would think back pressure would interfere with the one way valve.
12-15-2009, 06:58 PM
#393
1955 22' Safari
Great Lake State
Found this on YouTube, a couple of guys tested the backflow resistance of the valve. Perhaps you can visualize that as the backpressure increases it places more force on the membrane to remain closed. That is, as demonstrated in the YouTube video, until the backpressure becomes sufficient to force the entire membrane to reverse itself.
12-15-2009, 08:12 PM
#394
I have the same concern about backpressure. If you have a sealed tank with no external vent, then any fermentation in the gray water tank would exert backpressure on the downstream side of the valve and prevent free drainage of the shower.
A few inches of backpressure on the tank side of the valve could cause a few inches of backup in the shower.
Not a problem if you also have a regular tank vent. Or if you keep the pH of the graywater high enough to prevent fermentation.
Otherwise, might be a problem.
12-16-2009, 04:02 PM
#395
1955 22' Safari
Great Lake State
All of my tanks will be vented to the atmosphere, the shower will have its own gray water tank. The reason that I going with the Hepvo is space, I'm micro managing the space.
toastie
12-16-2009, 08:43 PM
#396
Bothell
re-build
toaste, i have read all your post tonite. wow, that is all good stuff. way to go. your AS will be better then new and better then the new ones. AS should take notice. anyways, great job, great post, very interesting. thanks, can't wait to see the finnish of this.
Outlaw
12-16-2009, 10:19 PM
#397
1973 31' Sovereign
Portland
, Oregon
I was thinking some more about this and I think that you are right about still needing to vent the tanks.
Malcolm
12-22-2009, 11:03 AM
#398
1955 22' Safari
Great Lake State
Thinking about running the sewer hose through the sewer hose holder kit, then, permantanly fastening the hose to dump valve and design it that the kit can pivot. Any other ideas out there with pictures?????
toastie
12-22-2009, 11:29 AM
#399
Elkhart
, Indiana
I saw this a while ago. It may give you a few more ideas.
Mike
Have a great day!
TAC # IN 1 Air#27922
