Old 02-05-2022, 06:14 PM   #1
1975 31' Sovereign
Stanton , Nebraska
Shell reattachment problems
Just put the shell on repaired frame new floor over the weekend. It went better than expected although from mid curb side to rear curb and street side the old glue line isn’t lining up with the c channel. Any suggestions? We have tried a ratchet strap and maybe got a millimeter more. Doesn’t seem like any of the shell is hung up anywhere. The floor is level side to side and front to back. Thank in advance
ID:	411631   Click image for larger version
rhonda70 is offline   Reply With Quote
Old 02-05-2022, 06:36 PM   #2
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Greetings from Colorado and welcome to these Forums. I'm sorry to say I don't understand your problem. I can say you are certainly not the first to have problems reattaching the body to the frame and subfloor. Did you repair the frame? Did you replace the plywood subfloor? I don't understand what a "glue line" is.
Maybe someone more knowledgeable than I will chime in and help you out.
David
WBCCI #8607 VAC Region 11
KnowledgeBase trailer renovation threads: 69 Globetrotter, 76 Sovereign, 75 Overlander, 66 Trade Wind Such fun !
Old 02-05-2022, 06:41 PM   #3
1966 22' Safari
Fredericksburg , Texas
We just went through that same issue with a 63 Bambi. We were also level. The frame will flex. We jacked up the rear at the center of the bumper. I eased the rear up by an inch or so. When we had the shell where we wanted it, we installed clecos through the shell into the C-channel then released the jack. The shell stayed in place. We also did that to our 55. The frame relaxed down to level. Just a suggestion. Good luck
Bubba L is offline   Reply With Quote
Old 02-05-2022, 06:47 PM   #4
1966 22' Safari
I’m assuming the glue line means the interior sealant they use to seal the buck rivets from the inside?
Old 02-05-2022, 08:42 PM   #5
1975 31' Sovereign
Stanton , Nebraska
Yup that the sealant from the original bond. Didn’t clean it up to use it as a guide. Thx for the info !
Old 02-05-2022, 08:44 PM   #6
1975 31' Sovereign
Stanton , Nebraska
It’s a repaired frame and new floor. The glue line is where the shell originally met the c channel. Some type of caulking obviously not glue poor choice of words
Old 02-08-2022, 08:23 AM   #7
1987 34' Limited
Hantsport , NS
As noted if you want to use the old channel lines/holes gently experiment with a few jacks under the frame rails and you'll be able to watch adjustments in the alignment of the channel to the body. For example, putting pressure from a jack under one corner of the rear may affect the opposite corner at the front.
Daytonacoupe is offline   Reply With Quote
Camper Shell or No Camper Shell for Pickup TV KJRitchie Tow Vehicles 28 03-14-2017 07:23 AM
HELP! Can I fix sagging Outriggers with shell on? Or just pull the shell? Mixter Repairing/Replacing Floor &/or Frame 3 01-24-2013 11:59 AM
Shell on? Shell off? Althea68 Repairing/Replacing Floor &/or Frame 55 04-01-2011 09:35 PM
Problems Problems Problems pjzuk General Motorhome Topics 6 09-03-2007 07:25 AM
Shell Off vs Shell On Summary mbatm01 Repairing/Replacing Floor &/or Frame 82 01-09-2006 05:46 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
