The decision to do a Full Monty or not will depend on what you find when you take out the interior (keeping everything until the project is done) to assess the subfloor condition and drop the under tray to assess the frame condition. Take the interior out and moisture meter the subfloor; drop the undertray and if the frame is in great shape, PQR-15 the frame and re-insulate. Why do work that doesn't need to be done.
Please keep in mind when taking out the interior to section off the trailer into four or more sections and try and weigh items that you take out of those sections, which will give you an indication of where the weight goes. Remember, if you take weight out of one section, say the back, you will need to take out the same weight in the front to keep the trailers balance.
It would be really good to have a couple of these under the axles on both sides and a scale under the hitch to weigh the trailer before you gut and weigh the trailer as you add interior weight.
https://www.uline.ca/BL_2212/Low-Profile-Floor-Scales
It's a lot more science than design.
Cheers
Tony
