Originally Posted by Luftstrom
Hi Folks:
Finally ready to start a shell-off renovation. I would like to spare myself the trouble of taking off the AC. It is not leaking now and why invite that? Plus it is a lot of extra work.
What are your experiences and thoughts? Take it off or leave it?
If it's not leaking now, it could certainly start leaking tomorrow. It only takes about 1/2 hour to pull an a/c unit if you've done it before, maybe 45 minutes if it's your first time. Not much to it and it will give you a chance to put new gaskets under it.
When I got my trailer I redid nearly all the external gaskets & seals. There were a few that looked good, and I made the same assessment as you - it's not leaking so why invite trouble? Sure enough, the only problems I've had since then have been the few things that I left in place.
If you're going to the effort of removing the shell to fix problems, then pulling an a/c unit should be just another simple step in the process. Likely you already have a gantry in place, and you can use it with a block & tackle to lift the a/c off the roof. We did something similar with a beam in the barn where ours is stored.
