Sitting since 1976! 50 years of neglect! This trailer is very likely a candidate for a complete rebuild--the damage you see to your tongue is liikely just the tip of the iceberg.
If your tongue is in that bad of shape, hold onto your hat, because the rest of the frame will likely be in bad shape as well. Subfloor is likely rotted out, appliances shot, mice in the walls, etc., etc..
Go to the top of the page and click the "portal" tab. Scroll down and keep your eyes on the right hand side, and you will find a link to the "trailer inspector's checklist." Download it and go through your trailer with it. This will give you a little more complete idea of what you are up against. You won't be able to fully evaluate the frame without dropping the belly pan, but once you have gone through the checklist, you may have a better idea of whether/how you want to proceed.
On the good side, at least Arizona is a dry climate (assuming the trailer didn't spend the last 50 years on the Florida panhandle).
good luck!
