Roll Vinyl vs. Vinyl Tile in Bathroom?
Greetings Bob!
Fowler RV Interiors installed new industrial grade Congoleum sheet vinyl in my Airstream in 2003. I am totally satisfied with the results. The Congoleum is easy to maintain and has a heavy duty wear layer that has not required any kind of waxing to this point.
My Minuet has floating laminate flooring also installed by Fowler RV Interiors in 2005. I have also been very well pleased with this flooring, but would still have gone with sheet vinyl tile if it weren't for the Minuet's aluminum composite floors. While I haven't had any particular problems with the laminate flooring, I am just more comfortable with the long-term durability of the Congoleum.
Kevin
Kevin D. Allen
AIR #827
1964 Overlander International
1978 Argosy Minuet 6.0 Metre
