Old 05-01-2011, 11:46 PM   #21
Tool Hoarder
West , California
Originally Posted by tracker View Post
I am about ready to start removing the rotten sections of my sub floor. I would like to do what you did and use the old front section as a template if I can get out in one piece. I understand the elevator bolts that hold the plywood down where it passes under the "c" channel but I don't see how the other side of the subfloor is attached whwe it butts up to the next section of plywood is it screwed in place from under the trailer?
I think what you are asking is how the plywood is joined together right? It is joined underneath by strips of plywood (sorry I don't have the exact dimensions) you need to remove part of the belly pan to access this area.
also this is how I removed my elevator bolts. http://www.airforums.com/forums/f36/1965-rehab-71458-3.html#post924149 check out my thread post #32.
St Pierre sorry if I hijacked your thread, nice work BTW.
marzboy is offline   Reply With Quote
Old 05-02-2011, 11:16 AM   #22
ALUMINUM OBSSESSION
1993 34' Limited
Hamilton , Ontario
Nice Job!!! . You should be proud of yourself!!
william Haym is offline   Reply With Quote
Old 05-03-2011, 09:56 PM   #23
StPierre's Avatar
1965 22' Safari
Rescue , California
Tracker You may have to remove the sub floor to the first joint . At that point you will find two scabs at a frame cross member . As marzboy said you will have to pull the belly pan . Sounds harder than it is GOOD LUCK . Marzboy not a problem all help is good.
The St Pierre's
StPierre is offline   Reply With Quote
Old 06-12-2011, 09:45 PM   #24
StPierre's Avatar
1965 22' Safari
Rescue , California
Taillight rebuilding complete
Completed the rebuilding of the taillight housings. One thing I learned, if you think you have it sanded smooth enough, sand some more!
We have checked all our wiring, that looks good. We have pre-wired for the microwave my wife can't live without! All lights inside and out check out good. Is there anything I am forgetting before I put the insulation and the interior walls back on?
Our '65 Safari still has the original TV antenna. Does anyone still use this original TV antenna? Seems like most of the pictures of Safari's we see do not still have the original antenna.
Name:	Painting the taillight.JPG
ID:	132353   Click image for larger version
Name:	Restored taillight.JPG
The St Pierre's
Old 06-13-2011, 05:53 AM   #25
2vets's Avatar
1960 24' Tradewind
St. Albans , Vermont
Looking great! What did you paint your floor with?
https://1960airstreamtradewind.blogspot.com
Love. You can learn all the math in the 'verse... but you take a boat in the air that you don't love... she'll shake you off just as sure as the turn of the worlds.
2vets is offline   Reply With Quote
Old 06-14-2011, 09:05 PM   #26
StPierre's Avatar
1965 22' Safari
Rescue , California
I used deck and porch paint from Orchard Supply . Two coats, we were real happy with the finish .
The St Pierre's
Old 06-17-2011, 04:08 PM   #27
Tool Hoarder
West , California
Hahaha I know! I have to really work on my fiberglass/bondo skill. Your light houseing looks great.
Old 01-26-2015, 10:21 PM   #28
(-1 Rivet_
REDSLED88's Avatar
1965 20' Globetrotter
Jackson , California
St Pierre, did you use bondo to redo your tail light housings?
They look great,
Thx
TIMK
Thanks in advance!
TAC CA-77
REDSLED88 is offline   Reply With Quote
Old 01-27-2015, 08:09 AM   #29
StPierre's Avatar
1965 22' Safari
Rescue , California
Redsled88 I used a body filler with strands of fiberglass , I found it at a auto paint store.I used it on the inside and out side of the housings,so far still looks good after some long road trips
The St Pierre's
Old 02-04-2015, 11:24 AM   #30
(-1 Rivet_
REDSLED88's Avatar
I think I'm going to use a little acetone and some lego pieces to make a glue for the cracks, and then cover with Fibertech by Evercoat. It's a reinforced polyester body filler, which should have enough strenght to do what I need.
Thanks for the info
TIMK
Thanks in advance!
TAC CA-77
1965 safari, 22', floor repair
Aft relief tube dripping through floor below sink kaiaua 1974 - 1979 Sovereign 5 02-21-2011 10:21 AM
The frame is ok ~ Patching the floor. LawChick Repairing/Replacing Floor &/or Frame 12 01-30-2011 02:39 PM
Replacing center roof vent in a '79 blickcd Roof Vents, Skylights & Fans 1 01-29-2011 04:58 PM
Fresh water tank relief valve "bumps" above floor? DanielB Fresh Water Systems 12 01-19-2011 06:00 PM
How to attaching the floor DanielB Repairing/Replacing Floor &/or Frame 17 01-09-2011 07:21 PM
