09-30-2002, 08:04 AM
Replacing Pipe Frames
I have a 1948 Trailwind in need of a chasis upgrade. I have heard a collector, Bud Cooper, has blue printed plans for a new frame. Does anyone know how I would get access to the plans? Has anyone else done the changeover? Any advice on the subject would be appreciated. Gene
09-30-2002, 09:38 AM
1956 22' Safari
2015 27' Flying Cloud
Conifer/Evergreen
You could contact Bud Cooper through the VAC
VAC Contacts & Officers
Region 9: OK-TX (except MT zone)
Bud Cooper #26019
RUC00p@aol.com
1401 S. Cage Blvd. #600
Pharr,TX 78577
Good Luck!
Shari
09-30-2002, 12:16 PM
Shari: Many thanks for the contact. I'm just starting the restoration. Why do I have a funny
feeling I'll be back on the forum with other questions? Gene Dallago
03-06-2005, 11:16 PM
Breckenridge
Pipe frame question
I have just purchsed a 49 18' Trailwind. It is wise to just get a new frame? What is the problem with the pipe frames? The e-mail for Bud is not working.
Erica Sherwood
03-07-2005, 07:55 AM
Moderator Emeritus
1978 Argosy Minuet 6.0 Metre
Anna
Greetings Erica!
It isn't so much that the pipe frames weren't strong enough, rather its an issue with how they react to the rigors of age and use. The pipe frames were very light weight, and now that they are 50 or more years old age/use problems are the issues. The center pipe can either be the subject of rust through (most critically near axle or where it is hidden between the axle and front edge of coach) - - or the welds that hold the cross supports to the central pipe can fail permitting the central pipe to be pulled out of the frame. Another reason some have replaced their pipe frames was to increase the carrying capacity to allow for the addition of "modern conveniences" that weren't included in the 1940s and early 1950s.
Good luck with your coach!
Kevin
Kevin D. Allen
AIR #827
1964 Overlander International
03-07-2005, 08:24 AM
Contributing Member
Austin (Hays County)
Bud Cooper's frame
I had the privelege of sitting across from Bud at a rally dinner. His tales of rebuilding his trailer were interesting to say the least.
The neat thing about Bud Cooper's frame is that it retains the appearance of the pipe frame. He has a short section of non-structural pipe poking out the rear of the trailer.
Bud also added a rear bumper of aluminum channel to his trailer. He gave the first channel he bought to a metal shop to bend. Guess what? They bent it in the wrong direction and he had to buy another piece of channel.
John W. Irwin
WBCCI #9632
03-07-2005, 09:20 AM
1948 16' Wee Wind
1953 21' Flying Cloud
Denver
Hi Erica:
The early pipe frame Liners had a centered 4" diameter seamless pipe that ran the length of the trailer, which was its "backbone". Thin aluminum "C" channel floor supports ran out perpendicular and attached to this center pole pipe frame, often by rivets. There were also two steel "C" channel side rails that were parallel to the pipe frame and went from the front spring hanger to the rear spring hanger on each side. They were just a tad longer than the wheel well opening, and attached to the center pole via thicker floor supports.
Early in the 1949 model year, the factory strengthened the pipe frame chassis by (1) lengthening the outside spring hanger frame rails so they extended forward on both sides to about the front of the door (this stiffened up the floor a bit, reduced floor tortional flexing around the centerpole, and allowed a bit more weight to be carried along the walls); and (2) added an exterior doubler to the front 3 feet of the pipe frame to reduce flexing of the pipe in this area. To see if your trailer has the first upgrade, remove the small angled piece of aluminum where the door threshold meets the belly skin and look inside to see if you see the extended side frame rails.
As Kevin mentions, the longer term weakness in the pipe frame trailers is the attachment of the centerpole to the perpendicular floor supports. If that connection degrades, it is possible to pull the centerpole out from the trailer. If the pole can be rotated, you are in immediate trouble! A second problem is rust inside the centerpole, which reduces its wall thickness and may lead to it snapping or tearing apart from metal fatigue due to repeated flexing.
The centerpole worked OK for the very light 1940's trailers with few appliances. But as customers demanded more and heavier appliances and amenities, the centerpole pole frame reached its limits. Airstream changed over to "A" frames in the 1950 model year, which was a stronger design. Silver Streak Trailer Co. continued to use centerpole frames on their Clipper trailers well into the 1950s, but I'm not familiar with SS construction details.
Whether you need to replace the pipe frame in your '49 Trailwind depends on its current condition and your intended use of the trailer.
Fred Coldwell, WBCCI #1510, AIR #2675
Denver, Colorado - WBCCI Unit 24
Airstream Life "Old Aluminum"
Airstream Life "From the Archives"
03-07-2005, 12:49 PM
Corona
Gene Dallago.
The front part of the pipe frame should be replaced with a standard "A" frame.
The main reason is that you cannot easily hook up a weight equalizing hitch to the pipe, let alone a sway control. Plus the coupler you have is straight from Disney.
The rest of the pipe frame can be reinforced sideways with steel cross members instead of the aluminum cross members. You can also add aregular
steel frame similiar to later models.
That would insure stability and adequate frame strength.
We have made that change for several owners.
03-07-2005, 01:53 PM
1959 22' Caravanner
Atlanta
Inspect it carefully. If you can document the coach was in a mild climate in reguards to Salt on the roads or hight rain fall then it might be fine. If in doubt then thats when you need to concider it. If you are not trying to do a concourse retoration and making it ready for frequent use then replacing it might not be a bad idea.
Making a frame is not really difficult. I have built a couple utility trailers and done repairs on our Airstream. Its really a matter of the right tools for the job.
Steel prices are up and while not really difficult for a welding shop it is time consuming to make a one off frame to match and existing shell. Just don't let a fabricator try to over build it. They need to understand that the body work is part of the frame. 4 inch BENT not iron C channel or 4x2 Box would be the best choices. Personnaly I like the 4x2 box with around 1/8 inch wall thickness. 24 inches on center for the crossmembers ( here the Bent C would be the better choice). Plan any upgrades of storage tanks before you start the work.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
03-09-2005, 06:49 PM
Breckenridge
Thank you all for your help. While some of the information was greek to me, most was very helpful. My uncle is a welder and would gladly help me, I just need to know what to do. I understand you all have done it, and that is great. But how did you do it? Will I have to take the body off the frame? The first upgrade will be the frame, I'm not clear on all of your answers what the answer is. Thank you.
Erica Sherwood
03-09-2005, 07:04 PM
Corona
Erica.
It would be best if you took the shell and floor off.
More than likely part of the floor will need to be changed as well.
Additionally, when you have the floor off, you can alter the frame so that you can install a Henschen axle, even with disc brakes, if you wished.
We can help you with the axle installation info, should you decide to take that approach.
03-11-2005, 10:12 PM
Breckenridge
cost??
What does something like this cost? Approx...I understand you don't know until you see it, but worse case scenario.
Erica Sherwood
03-12-2005, 09:27 AM
1959 22' Caravanner
Atlanta
Well steel prices are up. I do my own fabrication on such things so I couldnt tell you the labor end.
Last time I bought Box Tubing retail It was about 1.80 a foot. So two main rails. I am guessing in the raw steel your probably looking at about $350-400 on the low end but with current prices probably a little more. Labor I don't know
1959 22' Caravanner
Atlanta, GA
03-13-2005, 08:59 AM
Breckenridge
replacing pipe frames
Fred,
I removed the threshold piece and I see a piece of aluminum extending out all the way to the edge of the trailer where the belly pan meets the body. I have the upgrade, right? There isn't much but surface rust on the centerpole and it has been parked for a really long time in a good climate. I don't really feel I need a weight distribution hitch, it doesn't weigh anything at all and I have a 3/4 ton diesel. Would I still need to put an A frame at the front?
Erica Sherwood
03-13-2005, 10:08 AM
1948 16' Wee Wind
Denver
Fred, I removed the threshold piece and I see a piece of aluminum extending out all the way to the edge of the trailer where the belly pan meets the body. I have the upgrade, right? There isn't much but surface rust on the centerpole and it has been parked for a really long time in a good climate. I don't really feel I need a weight distribution hitch, it doesn't weigh anything at all and I have a 3/4 ton diesel. Would I still need to put an A frame at the front?
Hi Erica:
The aluminum piece you saw that is perpendicular to the centerpole pipe frame is simply a crossways floor support; that is not the upgrade. Look in the wheel well and notice front to rear steel piece that the spring hangers are attached to. If that piece of steel continues forward inside the belly skin (parallel to the centerpole) and continues to the front of the door, then you have the upgrade. So, what you are looking for in the thresh hold "hole" is a "C" channel running rear to front, parallel (not perpendicular) to the pipe frame centerpole. If it is there, the "C" channel will impair a clear view of the centerpole inside the belly skin.
I agree that you don't need a weight distributing hitch for your Trailwind, especially when towing with a 3/4 ton diesel! The 1949 Trailwind weighed 1,500 pounds completely furnished, and your 3/4 ton diesel should handle that with nary a grunt.
I do not like the bad idea of using a weight distributing hitch on an original pipe frame trailer. I think using one would greatly increase the likelihood of damage by adding stress and load that the centerpole was never designed to carry, thus fatiguing the metal pipe much faster than through normal towing. Two years ago I saw photos of a small pipe frame trailer whose pipe broke about a foot inside the belly skin while it was being towed with a weight distribuiting hitch by a California used trailer dealer (not Andy). He ended up scrapping out the trailer instead of repairing it.
Assuming structural soundness, which I can't gauge over the Internet, I cannot recommend adding an "A" frame to your 19' pipe frame trailer. If the frame and floor are sound, and you don't intend to transport lead or add additional weight beyond what was there originally, then enjoy your Trailwind as it was built. Your 3/4 ton diesel can handle it handily. OTOH, if the pipe frame is damaged such that it requires replacement, for heavy duty use I'd replace it with a "A" frame instead of another pipe frame. But it sounds like that is not your situation.
03-13-2005, 12:02 PM
Breckenridge
I can not see the pipe frame. Instead I see a piece of metal that looks squared on the edges. This is in front of the step closer to the tongue.Looks like the piece you were talking about. Is there anything else I should look for? Thank you so much for your help.
Erica Sherwood
03-13-2005, 12:30 PM
1948 16' Wee Wind
Denver
Erica:
Look at the front of your pipeframe, under where the propane tanks would typically mount. Is the pipe double thick there? Has a sleeve been slipped around the pipe frame and welded in place? If yes, then that's the "doubler" to strengthen the first 3 feet or so of the pipe frame.
Fred C.
03-13-2005, 02:04 PM
Breckenridge
Yes Fred, there is a sleeve piece of metal around it. It looks double walled right there.
In the back, the pipe frame looks smashed like someone might have dragged it on a dip. Should I be concerned? I do not see any other damage to the frame, except there where it protrudes out.
Erica Sherwood
03-13-2005, 08:16 PM
Breckenridge
frame length
Fred,
You mentioned that my trailer was 19' in frame length. I thought they removed one foot in 49 just in front of the door and made it an 18'. The original brochure says 16' and 18' overall. I am almost certain it is 18'. Could I be mistaken?
Erica
Erica Sherwood
03-13-2005, 09:11 PM
1948 16' Wee Wind
Denver
Fred, You mentioned that my trailer was 19' in frame length. I thought they removed one foot in 49 just in front of the door and made it an 18'. The original brochure says 16' and 18' overall. I am almost certain it is 18'. Could I be mistaken? also, yes there is a sleeve piece of metal around it. It looks double walled right there. In the back, the pipe frame looks smashed like someone might have dragged it on a dip. Should I be concerned? I do not see any other damage to the frame, except there where it protrudes out. Erica
Hi Erica:
Upon seeing 1948 at the very beginning of this thread for a different trailer, it stuck in my mind, notwithstanding you clearly mentioning earlier you have a 1949 18' Trailwind. The key identifier, besides actual measuring, is whether or not a foot or so of side skin appears between the door and the front end cap. My mistake for growing your trailer an extra foot. Now, with that 1' shorter trailer, you can derate your 3/4 ton diesel to 11/16th ton. :<>
The doubler sleeve around the front pipe frame is more good news that shows your Trailwind came with the strengthened pipe frame. Don't worry about the smashed rear tip, as you've gained a few inches of curb and gutter clearance. But if you're really feeling circular, you can have it bent back to round, perhaps by a welder who could apply some very localized heat to coax it back out.
By the way, what is it's serial number? And when do we get to see baby trailer pictures?
