Old 07-16-2020, 07:27 AM   #1
1962 24' Tradewind
Quakertown , Pennsylvania
Reflectix on underside of subfloor?
Anyone see any issues with putting Reflectix on the underside of the sub floor and bolting down the panels. I did this on the first sheet, then metal taped the edges. My therory with taping the edges is that's where most of the moisture issues would be so it should help. It looks great and should make a good thermal brake etc. My only concern is am I going to trap moisture and cause and issue down the road? Plywood is marine grade treated with penetrating epoxy on all sides.
62rosie is offline   Reply With Quote
Old 07-16-2020, 07:42 AM   #2
1969 18' Caravel
Greenville , whereEverIroam
Images: 20
So reflectix isn’t a very good thermal insulator. But it does a pretty good job of reflecting radiant heat as long as there is a gap between the reflectix and the surface it is shielding.
I think the best insulator under the floor would be a good spray foam. The newer formulations do not turn to dust bouncing down the road like the old ones did. Airstream did this on some model years back in the past, and I have seen pictures of the subfloor on the underside looking pristine after the foam was scraped off.
skyguyscott is offline   Reply With Quote
Old 07-16-2020, 11:01 AM   #3
kidjedi's Avatar
1972 25' Tradewind
1976 31' Excella 500
1974 31' Excella 500
Denver , Colorado
With both the reflectix and the tape, you will likely be just creating potential moisture issues. Also, putting reflectix between the frame and subfloor will allow motion and create squeaks!
If you've epoxied the subfloor, especially the edges, you should be good.
The best insulation for underneath is 2" PIC (you can get it at Lowe's/HD) with an air gap between the panel and subfloor. It does not hold water and has the best R value and lowest weight of readily available insulation materials.
25' 1972 Airstream Trade Wind Land Yacht (heavily customized)
2006 Jeep Liberty CRD (diesel)
BeahmStream.com
kidjedi is offline   Reply With Quote
Old 07-16-2020, 11:47 AM   #4
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
I respectfully disagree with your idea because:
- traps moisture (there will always be some)
- moisture = mold = rot = metal rust, etc
Same with spray foam. When plywood floor gets water in it, there must be a way for it to get out... vibration on the road may cause delamination. I would not want to lay under the AS to spray the foam... and you do not want to spray inside the belly pan....rust, etc
Part of why AS uses the pink stuff. Gets wet, lots of airspace so dries quick..
Just thoughts...
Peace and Blessings..
Channing
WBCCI# 30676
Old 07-16-2020, 12:21 PM   #5
SuperTrouper's Avatar
2008 27' International FB
Petaluma , California
Hi 62Rosie!
If you read through this thread you'll see the problems I had with reflectix (factory installed). Given that my model 27FB had water ingress issues but the reflectix trapped the water. https://www.airforums.com/forums/f39...ml#post1262866
Further down in the thread you'll see that I used extruded insulation 1/2" away from the floor to allow for some air movement. https://www.airforums.com/forums/f39...ml#post1271268
We don't camp in cold climates but have not noticed a cold floor in the rear of the trailer after the update.
Good luck with your repair/renovation of the Caravel. - Brad
SuperTrouper is offline   Reply With Quote
Old 07-16-2020, 12:31 PM   #6
kidjedi's Avatar
1972 25' Tradewind
Denver , Colorado
FWIW, I would say that "the pink stuff" definitely does not dry quickly. That's why the polyisocyanurate panels are so great. I've submerged it in water for more than a year (seriously), and it's back to completely devoid of water (as indicated by weight) in less than ten minutes.
BeahmStream.com
Old 07-16-2020, 07:35 PM   #7
1962 24' Tradewind
Well it looked nice, but you folks have confirmed my fears. Besides it will be easier. After I finish my plumbing layout, I'll remove the reflexive. I do think I will wrap the in floor gray tanks that I'm adding as they will have nothing. Thanks folks!
Underside of 65 Safari? reddoor Belly Pans & Banana Wraps 0 04-21-2011 09:12 AM
Underside issue ramseyny 2004 Safari 2 07-28-2010 08:33 PM
charred underside of refrigerator counter? barts Refrigerators 7 02-18-2010 08:59 PM
Factory tour ... Reflectix under subfloor? Zstream Repairing/Replacing Floor &/or Frame 4 07-30-2008 05:01 AM
Underside damage truck tire tread - 2004 Classic gklott 2001 - 2005 Classic 1 06-11-2004 08:15 PM
