Originally Posted by Mrmegafoz
Hey Hi Ho Silver! and all,
We've got the frame exposed, cleaned-up, and almost ready to be painted. And, thankfully, it looks great! As far as the frame flange issues goes, would adding the lift kit block resolve the bolt up issue? If I'm reading the info right, the lift kit is basically a spacer that drops the axle below the flange.
Thoughts?
Jamie
Tough to say with certainty since these old trailers have a bunch of variations.
If you have the dimensions for the lift blocks, measure your flange to see if they will fit. Top of the lift block to the center of the hole. Bottom of your frame rail down to the bottom of the flange will tell you.
I haven’t installed any lift blocks but from what I’ve seen, they lower the axle tube so it no longer rides in the slot in the flange.
