Old 03-13-2023, 04:44 PM   #1
Seven Valleys , PA
Pipe frame subfloor
I am looking at buying a vintage airstream to restore, I found one I am interested in but it has a pipe frame.
How is the shell connected on the pipe frames? I was wondering if the subfloor can be removed without pulling the shell or does the subfloor go into a channel that holds the shell on? I was hoping I could remove the subfloor to clean and repair the frame if it is just minor damage without pulling the shell. The owner says the floor is solid but he cut a couple small holes in it to be able to inspect the frame.
I know there is a lot of debate on the safety of the pipe frames
Stonewall is offline   Reply With Quote
Old 03-13-2023, 07:06 PM   #2
1966 22' Safari
Fredericksburg , Texas
You may consider contacting MrRivet or MsRivet here on the Forums. He’s working on a 48 and Sprouty is working on a 47. Good luck
Bubba L is offline   Reply With Quote
Pipe frame owner.... Whats under you subfloor? Sprouty 1947-1949 Liner 12 04-24-2022 07:58 AM
1950 Silver Streak Clipper - Pipe Frame robandzoe 1947 - 1953 Clipper 12 04-10-2019 11:42 PM
1947-1950 pipe frame axle, springs and frame rails Sprouty Airstream Classifieds 0 09-25-2016 11:50 AM
HELP -- does a '51 Clipper have a pipe frame? Corraleno Repairing/Replacing Floor &/or Frame 5 12-10-2007 12:24 AM
1950 Cruiser # 6032 pipe or ladder frame? Jim Jarzabek 1950 - 1958 Cruiser 11 01-12-2006 07:31 AM
