Old 06-29-2020, 12:46 PM   #1
1961 19' Globetrotter
1959 18' "Footer"
santa cruz , California
Pipe frame replacement
Looking at either restoring or replacing a pipe frame. I'd like to replace with a modern ladder frame. Who is making custom ladder frames in central CA or near by? Thank you.
greenrig is offline   Reply With Quote
Old 06-29-2020, 01:34 PM   #2
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Well.... a deep hole in the ground.
Well, you could buy the best arc welder made, take.a.metal fabricating and welding.course, buy the materials and laser levels, spend 6.months building your own frame.... and probably get it faster and less expensively than paying someone else whose skills are unknown. And you'd have a second lucrative career.
Area 53. Is your best bet if you aren't handy (or masochistic).
Foiled Again is online now   Reply With Quote
Old 06-29-2020, 02:11 PM   #3
1959 18' "Footer"
Originally Posted by Foiled Again View Post
Well.
Area 53?
Old 06-29-2020, 04:25 PM   #4
Proof reading GOOD, Paula BAD - fat thumb award
Area 63 Productions.
Old 06-30-2020, 11:01 AM   #5
1959 18' "Footer"
Thanks for that. A bit far for us. We'll be doing all the work except for the frame manufacturing so what I had in mind was someone who specializes in and does nothing but trailer frames metal fab etc. Thought I remembered on here years ago someone recommending a business like this.
Old 07-01-2020, 08:16 AM   #6
1977 31' Excella 500
Spring , Texas
Build your own frame. It really is a lot easier than I thought it would be. Get a good welder and scrap and start practicing.
Also - plasma cutter is worth every penny for making cuts.
1977 31' Excella 500 full restoration: Excella 500 Off Road Build
GPurcell is offline   Reply With Quote
Old 07-01-2020, 10:18 PM   #7
1959 18' "Footer"
Thank you for the inspiration!
Old 07-01-2020, 10:46 PM   #8
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
Frame building
greenrig, Contact Inland RV in Corona, Ca. They did lots of Airstream modifications for many years and also built out special trailer mods like a big toaster mod for one I can think of, they may be able to build you a frame. I would also check with local to you welding or metal fabrication shops as well. Then too you will want to check with a trailer service shop about a new frame and axle(s). Being you are having a new frame made they may be able to advise you on what the requirements would be needed on the frame to mount new axle(s). Most shops will want to have old frame to get an idea of what your needs are.
1967 Safari Twin "Landshark" w/International trim package
2014 GMC Sierra 1500 Double Cab SLE
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
BIGED52 is offline   Reply With Quote
Old 07-01-2020, 11:31 PM   #9
2007 22' International CCD
Inland RV no longer has a service department of any sort. They only sell parts. Sadly, we don’t have an Airstream dealer (Southwest Coaches) in Corona any longer, either.
(I live in Corona)
rmkrum is online now   Reply With Quote
1950 Silver Streak Clipper - Pipe Frame robandzoe 1947 - 1953 Clipper 12 04-10-2019 10:42 PM
1947-1950 pipe frame axle, springs and frame rails Sprouty Airstream Classifieds 0 09-25-2016 10:50 AM
Pipe Frame Replacement Vintage One Repairing/Replacing Floor &/or Frame 8 02-16-2010 06:11 AM
'48 Trailwind pipe frame replacement Benjo Repairing/Replacing Floor &/or Frame 3 07-07-2008 10:35 AM
1950 Cruiser # 6032 pipe or ladder frame? Jim Jarzabek 1950 - 1958 Cruiser 11 01-12-2006 06:31 AM
