Partial lower Interior Skin removal for floor repair
Hello,
In the course of replacing the floor in the rear of my 95 Excella, I was unable to find and remove all of the rivets holding the streetside curved interior skin in place. So I cut the panel at 15" above the floor to expose the channel. After replacing the floor, I repaired the panel. Here's how it was done
Before cutting the panel, I made a reinforcement batten from a 4ft length of 1-1/2" x 1/16" aluminum (bought at Lowes), and pressed it in place against the curved panel at 15" off the floor. Then I traced lines on either side of the batten with a marker, and then cut the panel approximately between the lines with a jigsaw (I could have a little straighter!). Unfortunately I lost the picture, but you can see the lines in the final picture.
After the floor was done, I placed the batten behind the in-situ portion of the panel and ribs, and clamped it in place with a small needlenose visegrip so as to drill and rivet it in place. After it was fully attached, then I repositioned the removed panel section and drilled and riveted it in place. After replacing the mouse fur, the cut line is not visible. If it were visible, it would be hidden by the bed or a strategically placed strip of trim.
