Old 10-28-2017, 08:29 AM   #21
Sag Harbor , New York
Ditto to the last two comments.
Do it right.
Old 10-28-2017, 05:07 PM   #22
1978 31' Sovereign
Aumsville , Oregon
Originally Posted by Air4563 View Post
Concerning your axles, I have been told that when the top of the wheel well appears to be inline with the rims, the axles need to be replaced. Also,since the axles are probably original, the rubber inside them has probably become hard. I replaced mine in 2015. It made a tremendous difference in the ride. If you choose to keep your axles at least replace the shock absorbers.
I didn't really know if these were original or not. I didn't have a reference point for suspension sag either though, so thanks for the tip on the rim lining up with the wheel well.
pvfjr is offline   Reply With Quote
Old 10-28-2017, 05:44 PM   #23
2007 22' International CCD
The other way of measuring is to check the wheel drop when you jack up the trailer. A good axle will drop 3 inches when fully unloaded.
Old 10-28-2017, 09:27 PM   #24
1978 31' Sovereign
Aumsville , Oregon
Looking at the trailer again, I've got quite a few inches before the rim lines up with the wheel well. I think I'll do the suspension droop test--I can't risk ordering parts unnecessarily.
Old 10-29-2017, 01:22 PM   #25
Dingo Girl's Avatar
1967 17' Caravel
Oak Creek , Colorado
If the arm on the axle is horizontal or above you need a new axle. If the arm is below Horizontal, say 22 degrees or so you are fine.
Dingo Girl is offline   Reply With Quote
Old 10-29-2017, 01:23 PM   #26
Dingo Girl's Avatar
1967 17' Caravel
This is while the weight of the trailer is on the axle.
Old 10-29-2017, 11:37 PM   #27
1978 31' Sovereign
Aumsville , Oregon
That sounds pretty straightforward, I'll have to try to get a good view of it. Eliminating the urine smell is paramount, so if the axle needs replaced, it'll have to wait a little while.
Old 11-02-2017, 10:24 PM   #28
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
If the axles are stock, its 99.99% that the axles are shot. The rubber springs will be cracked and broken.
Old 11-04-2017, 08:11 AM   #29
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Right choice. If your restoration takes 8 months and you do need axles they should be about the LAST thing you need, so change them out a week before you go camping!
Sadly, keeping the trailer ON the road is what keeps the rubber soft and exercised. Six year old axles could well be shot if the trailer has been yard art.
Buy a lottery ticket now and then and get the winnings to pay for some of the parts, etc.
Paula
sovereign
1978 31' sovereign mid bath tank location? Sirwalshalot Interior Restoration Forum 8 08-17-2018 07:00 AM
26' 1972 Rear Bath to mid bath BentMetal All Argosy Trailers 3 04-22-2017 03:37 PM
1975 Sovereign 31' mid bath waste tank replacement TheBstream Waste Systems, Tanks & Totes 6 07-27-2013 07:21 AM
1986 Airstream Sovereign 31' with Mid Bath eBay Watch Airstreams on eBay 0 06-26-2013 05:10 PM
1976 Sovereign 31' mid bath rear double DJSegura Trailer Values 1 05-03-2013 05:24 AM
