Old 04-28-2017, 02:50 PM   #1
@steadystreamincashios
Zcashio's Avatar
1968 28' Ambassador
1964 26' Overlander
1976 Argosy 26
Heber Springs , Arkansas
Looking for decent sandblaster for frame
Hi, I have a 15 gallon air compressor that pushes 4.6scfm and another smaller 5 gallon air compressor, but I'm looking for a sandblaster that these compressors could power well enough to do the job. Was hoping you guys could help me find one. Not looking o buy another bigger compressor, but then again you gotta do what you gotta do. Any info would be helpful. Posting a pic of frame and surface rust to show so you can have a feel for my project.
Thanks again,
Zach
Zcashio is offline   Reply With Quote
Old 04-28-2017, 03:13 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
How about just adding another tank for volume. Once charge and by the time you loose mini operating pressure you will want a beer anyway
2004 Excursion 4x4
Old 04-28-2017, 06:33 PM   #3
2021 16' Bambi
2021 22' Bambi
North Port , Florida
You wont get anywhere fast with that small of a compressor. I have a 120g tank and it runs a lot when blasting. I think you'd be better off looking for a blaster to come to you and take care of it. Look up dustless blasting. Prices are fairly reasonable
cliffcharb is offline   Reply With Quote
Old 04-28-2017, 07:19 PM   #4
AlinCal's Avatar
1991 25' Excella
2011 19' Flying Cloud
Santa Ynez , California
Been there with smaller jeep frame and a harbor freight blaster with 2 compressors running and not very effective at all. I never take my own advise but having a pro do it could be money well spent.
AlinCal is offline   Reply With Quote
Old 04-28-2017, 08:35 PM   #5
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
I bought a sandblaster from HF and did quite a bit of blasting using a 5 gal compressor with no problems not sure what tip I used but they come in different sizes the larger tip opening the more cfm required.
However; my compressor specs says it will put out 6.5 cfm and is belt driven.
Garry
Old 04-29-2017, 12:11 PM   #6
greenflag's Avatar
2016 30' International
Quartz Hill , California
I understand the feeling of accomplishment doing it yourself. Unless you think you will need to do more blasting in the future, another vote for Dustless Blasting.
greenflag is offline   Reply With Quote
Old 04-29-2017, 12:48 PM   #7
1963 22' Safari
Vail , Arizona
Sand Blasting
I bought the charming cheapie sandblaster from Harbor Freight for about $40. I used sand from Home Depot. I have a fairly small compressor and was able to get all the rust off of my frame (22' Safari, 1966).
This is NOT the recommended way to do it. Using sand is a good way to get silicosis if done long term. I used a mask and got the job done in a day or two. My setup was also outside in very wide open country (a rural area outside of Tucson)
morganobenn is offline   Reply With Quote
Old 04-29-2017, 01:05 PM   #8
1988 Argosy 32
Lomita , California
If you can find a shop and tow the frame to them and let them to do it,
its quick and the mess and crud stays with them.
If that won't work rent one for 1-2 days if they have a matching blaster git it also.
Wolfe is offline   Reply With Quote
is this a decent tow vehicle? Brian Schulz Tow Vehicles 19 10-03-2014 08:40 PM
decent campgrounds between Texarkana and Nashville? gypsybanker On The Road... 10 03-09-2013 04:20 PM
Decent No Cut Install $115 Backup Camera EvelynDickinson Audio, Video & TV 9 06-10-2011 12:11 PM
Frame Repair or New Frame muddy_hollow Brakes & Brake Controllers 14 09-26-2006 05:55 PM
is this a decent deal? Goin camping Trailer Values 6 06-25-2006 10:29 AM
