the flooring is vinyl in most of the new units...
and only attached at the perimeter or where INTERIOR bits fix to the subfloor.
i can imagine one of 2 approaches depending on size and location...
1. slip a thin backing material through the hole, then fill the spot with vinyl putty ~ the matching color.
-when dry sand smooth
2. enlarge the hole and sharply define the borders (circle, square, rectangle)
-again insert a backing sheet with adhesive facing UP.
-cut a section of fresh vinyl with the pattern matching at the edges and attach it to the backing sheet
-then carefully glue at the edges which will be ON the backing sheet...
____________
because the sheet vinyl is floating, any attempt to patch or glue that sticks to the plywood subfloor will be an issue.
good luck
2air'
