Old 08-29-2006, 11:57 AM   #1
Silver Mist
LI Pets's Avatar
Riverhead , New York
How would I fix this?
I can put one finger thru but it is only weak in about a 18" area. it is in the rear corner of a 31'
I was going to cut it out put bridge cleats in where needed and fiberglass the entire floor.
Any suggestions?
LI Pets is offline   Reply With Quote
Old 08-29-2006, 12:20 PM   #2
arodriguez60's Avatar
2008 27' Classic FB
1959 22' Flying Cloud
fairview , New Mexico
Images: 85
I would try a product called git-rot. they use it on boats.
arodriguez60 is offline   Reply With Quote
Old 08-29-2006, 01:30 PM   #3
Barkingdogg's Avatar
Newcastle , Oklahoma
Look at a product called polyall http://www.polyall.com/
I used it on spots on my floor and it worked great. If there is any material to bond to it will make it quite sound.
Barkingdogg is offline   Reply With Quote
Old 08-29-2006, 02:38 PM   #4
1963 19' Globetrotter
Orion , Illinois
I do a lot of wood restoration and for many years have used products from a company called Abatron. They have a product called LiquidWood , a two part epoxy product that would work very well for you. Ceck out their web site at Abatron.com.
These are professional grade products used in architectural restorations but the public can buy from them. Not cheap but the results are worth the price.
63air is offline   Reply With Quote
Old 08-29-2006, 04:03 PM   #5
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
all good ideas. I used a wood hardening product from Minwax, and then I also put a coat of a bondo type substance on it. Seems to be pretty solid now. I had an area of behind the beltline leak that caused rot in about a 6 inch spot on each side.
After I fixed the leak, I am able to use my pressure washer on the trailer and see no water inside.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 08-29-2006, 05:49 PM   #6
Silver Mist
LI Pets's Avatar
OK, thanks for the input, bottom line is I don't need to cut it just repair it with one of these epoxies.
After that I still plan on fiberglassing the entire floor so I should be in good shape.
THat corner is going to have a built in cabinet in the corner so no foot traffic.
THen I think I'll consider pergo on the floor.
