Old 05-17-2020, 02:28 PM   #1
wanatrail
2007 25' Safari
1993 34' Limited
State College , Pennsylvania
Hardwood removal 93 Classic
The 93 Classic Limited has a hardwood flooring (found under the vinyl flooring) problem. The hardwood flooring has severe damage from a leaking fridge (totally rotted out). How to take out the hardwood floor? Can I use a circular saw set to the depth of the planks and cut lines at right angles to the planks at increments back along the length of the floor? Then replace the flooring with marine grade plywood to act as a base for a floating vinyl floor planks?
ID:	368108   Click image for larger version
wanatrail is offline   Reply With Quote
Old 05-25-2020, 04:05 AM   #2
Ultraclassic's Avatar
2000 30' Excella
GTA , Ontario
That's how I would do it, you can set the blade a little higher first, and the planks should break out the rest
Tow Vehicle 2005 Ford F150 Lariat 367,000Kms 5.4L - 2012 Mercedes Benz GL350d - [not set up yet]
Ultraclassic is offline   Reply With Quote
Hardwood in Classic 345 Roquefort Airstream Motorhome Forums 4 04-28-2015 01:24 AM
New hardwood floors- finishing touches kween Floor Finishes 11 03-25-2013 08:31 PM
Hardwood in Bath rc707 Floor Finishes 11 06-16-2008 11:55 AM
New Hardwood Floors 87 34' Excella tslanier Repairing/Replacing Floor &/or Frame 1 10-12-2006 08:11 PM
Hardwood Concern J&C Floor Finishes 24 04-03-2004 02:54 PM
