Old 07-03-2020, 12:58 AM   #1
1960 26' Overlander
Oceanside , California
Frame rust
Hi Airforum I need help!!! I have been restoring a 1960 26 ft overlander for the past year. The interior is literally weeks away from being done. I inherited the airstream from a family member that bought it gutted and the person that they bought it from said the frame was repaired and totally good to go. When I started the reno I realized that the frame was not repaired, but just painted. However, the frame seemed overall to be in pretty good condition, so I welded in a couple cross members and a couple outriggers towards the back, painted it with high end paint and called it good. Fast forward a year and A LOT of work, and I just noticed rusting under the frame at the A frame. I feel pretty stupid that I didn't fully investigate the frame early on, but you see what you want to see, and I had in my mind I wasn't going to have to mess with the frame. Now I have an almost finished trailer and I'm worried about frame and the safety of the trailer. Any advice would be greatly appreciated! I am in San Diego county if there are any local experts.
libtech17 is offline   Reply With Quote
Old 07-07-2020, 08:23 AM   #2
1976 31' Sovereign
houma , Louisiana
Pictures would help a lot in understanding the extent of the rust. I just built a new frame and may be able to offer some advice to you. It is possible to weld on a new A frame with the subfloor on in my opinion.
CajunCan is offline   Reply With Quote
Old 07-07-2020, 11:07 PM   #3
1960 26' Overlander
Thanks for the reply! I tried to upload pictures and thought I did, but evidently no! I am not sure what I’m doing wrong. I’ll try again...
ID:	372208   Click image for larger version
ID:	372210   Click image for larger version
Old 07-07-2020, 11:09 PM   #4
1960 26' Overlander
As you can see I opened up the belly pan as well, there was no pin hole on the side, looks like some rust where water maybe sat between the skin and the frame. I have had two welders look at it and they both feel like they could weld to the frame about 4’ back and build a new a frame. What do you think?
Old 07-08-2020, 05:17 AM   #5
Kevin245's Avatar
Appears that the A-Frame is toast, replacing it isn’t a huge undertaking, The frame appears to be in good condition visually, I’d still poke around with an inexpensive scratch awl and tap on things with a ball peen hammer to confirm the limits of the deterioration. Then address the rehab with your welding service provider.
William C. Swinney
Old 07-08-2020, 11:09 AM   #6
1960 26' Overlander
Thanks for your input, I really appreciate it! -Tyler
Rust? What rust?? Black tank? What black tank??!? gadgetgeek Repairing/Replacing Floor &/or Frame 2 08-08-2018 10:20 AM
Rust and Frames Por 15 Zero Rust Tony S Repairing/Replacing Floor &/or Frame 10 02-20-2013 03:45 PM
Frame rust out eracism Repairing/Replacing Floor &/or Frame 2 08-07-2003 06:15 AM
Frame rust Ken J Repairing/Replacing Floor &/or Frame 5 07-13-2003 06:39 AM
Frame Damage (Rust under water Tank klanke Repairing/Replacing Floor &/or Frame 3 04-06-2003 08:34 AM
