So I have a 76
Sovereign and am fixing up the frame and have a few questions.
First, I am moving the tanks from the back to behind the axles. on the back of the frame I need to replace the last few feet because my frame ends are all wonky. On the bottom side of the frame there were 1/4 inch frame supports added, I assume to protect the tail and original tanks from tail dragging. Are these placed on mid bath models? Is there any other support reason to have them? I may put something back on as a protection for tail drag, still working that out.
Second, With moving the tanks to the mid bath location I need to wrap them. I am using factory replacement mid bath tanks from INCA. What I see most people do is make light aluminum boxes just to wrap them. Should steel be placed around the tanks to protect them from road damage with just an removable bottom to access or is the aluminum box sufficient?
Third, I also see many people cut out the center floor stringers to mount the tanks flush to the subfloor. I do not like this, although it would keep my tanks mostly inside the frame. I am currently planning to mount the tanks to the bottom of the stringers to protect the tanks from screws and to give my shower trap more drop room. Has anyone else placed the tanks lower? and if so did you have any issues?
https://robinsonairstream.tumblr.com/
Respectfully,
David Robinson
