Old 07-13-2020, 02:11 PM   #1
2020 19' Caravel
Louisburg , North Carolina
Floors feel funny
We have been looking for airstream. We found one we like only two years old but the floor by kitchen and bath is squeaky and feels like it may move when you step on it. Owner says he never noticed and it’s never gotten wet. Should we take the chance? WhT could problem be ? Thank you
Cardon is offline   Reply With Quote
Old 07-13-2020, 02:19 PM   #2
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Does the current owner weigh 400 lbs.? Even if he does, get an inspector to help you seriously evaluate this possible problem.
Pull up the wooden threshold and use a moisture meter, poking through the vinyl. If the current owner objects, walk away.
Old 07-13-2020, 02:26 PM   #3
Silvr_Bullet's Avatar
42° 2' 27" N / 74° 7' 6" W , US
You can purchase moisture meters that do not require puncturing materials to evaluate wood.
Silvr_Bullet is offline   Reply With Quote
Old 07-13-2020, 02:37 PM   #4
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Attachment 372794
VERY cool!
2019 Ford Expedition Platinum
Old 07-13-2020, 02:55 PM   #5
brokeboater's Avatar
2003 25' Safari
High Springs , Florida
Of course the owner never noticed anything. And all dents and scratches are from a previous owner. If the floor looks good and feels good it might be bad. If the floor looks bad or feels bad it's bad. Good floors don't feel "funny."
“While you live, shine / Have no grief at all / Life exists only for a short while / And time demands its toll.”
brokeboater is offline   Reply With Quote
Old 07-13-2020, 04:35 PM   #6
2018 25' International
Slidell , Louisiana
^ What he said
Brian
Old 07-13-2020, 05:46 PM   #7
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
The floor in my Classic 30 "feels funny" over the wheels. It is worse when the stabilizers aren't down. I recently had the sheet vinyl pulled up and vinyl plank put down. The subfloor was solid. I believe it is give in the suspension. Put the jacks down and see if the feeling is different. Also get a moisture meter and test. I have an inexpensive pin based model. The pins are like needles. When I put it through vinyl you can't see the holes unless you know what you are looking for, and they get less noticeable over time and the vinyl "heals".
Old 07-13-2020, 06:11 PM   #8
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Davidson County , North Carolina
My trailers move as I walk across the floor, as have every one of the 4 other Airstream trailers I have owned. Longer trailers move more than shorter trailers. Movement is normal. Soft spongy floor is not normal.
Putting down the stabilizers and chocking the wheels might make it feel more solid.
My 34's floor squeaks occasionally if setting out of level. My 25' does also, but rarely.
Alan
Old 07-14-2020, 03:08 PM   #9
2019 19' Flying Cloud
2006 16' International CCD
Front Range , CO
Back when I purchased my 2006 16CCD the floor was very firm vinyl.
My new 2019 19FC has a different vinyl-type flooring. When I first got it the floor felt funny to me. I think the 2019 flooring has a foam backing that "gives" a little when you walk on it...
trailerpup is offline   Reply With Quote
Feel the Fear and Do It Anyway Wardinbb 1959-69 Tradewind 32 10-19-2008 04:48 PM
Feel like we've joined a cult! Ken & Janice Member Introductions 13 08-06-2006 08:57 AM
I feel like I'm living in Ground Zero jcanavera Our Community 14 04-10-2006 07:02 AM
I feel withdrawal symptoms coming... yukionna Our Community 1 11-20-2003 06:09 PM
I feel like such an Idiot.... Pick Steps 3 10-24-2002 12:59 AM
