Old 03-18-2023, 10:43 PM   #1
Anchorage , Alaska
Flooring for a vintage vibe
I am working on a frame of restoration of a 1963 Bambi. I should be finishing the electrical & installing the interior skins as the weather warms.
One of the next steps will be installing flooring. Is vinyl tiles the way to go these days ?
What is a good pattern to preserve a vintage vibe ?
Aktundra is offline   Reply With Quote
Old 03-19-2023, 11:39 AM   #2
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
We've installed with sheet linoleum (Marmoleum) in both our previously owned '64 GlobeTrotter and our current '56 Safari trailers. Love the seamless install. It's a bit warmer under foot too being a natural material.
Shari
ID:	429296   Click image for larger version
Name:	int back-2.jpg
RMVAC | ACI - CO Unit (Formerly WBCCI) | BIRDY - our 1956 Safari | 1964 Serro Scotty
Old 03-19-2023, 01:51 PM   #3
1966 22' Safari
Fredericksburg , Texas
X2 what Shari did. We installed sheet Marmoleum in both our trailers without issue. The 63 Bambi I just helped a friend of mine with a shell off is also going to install sheet Marmoleum. The sheet is a few inches shorter in width than the trailer, but place the splice on your street side where it’s underneath furnishings if that’s the case with your Bambi. Good luck
Bubba L is online now   Reply With Quote
Old 03-19-2023, 11:42 PM   #4
57Vintage's Avatar
1958 26' Overlander
Battle Ground , Washington
Images: 22
If you like the vintage look of Marmoleum, you can also get it as a tile that has a good seamless look without having to glue down. It allows you to create patterns/color combos that aren't available in the sheet goods. It comes in 12X12 and 12X36 tiles so it has less joints than a lot of other tile products.
Name:	Marmoleum Flooring pattern.jpg
ID:	429318 Click image for larger version
Name:	Marmoleum Flooring.jpg
https://www.forbo.com/flooring/en-us...8pj1#panel_105
I installed the tiles on the entire floor and mounted the cabinets, etc on top. Basically securing those items through the tile into the subfloor. No issues with buckling or shrinkage in seven years.
Note: I do keep the trailer heated during the winter (60 degrees).
Harold & Rebecca
Our thread:
https://www.airforums.com/forums/f97...er-172124.html
57Vintage is offline   Reply With Quote
Old 03-20-2023, 01:04 AM   #5
InsideOut's Avatar
1956 22' Safari
Images: 108
Originally Posted by 57Vintage View Post
If you like the vintage look of Marmoleum, …No issues with buckling or shrinkage in seven years.
That’s the beauty of Marmoleum vs synthetic vinyl - it’s much more stable. It’s made from wood pulp, talc, jute & linseed oil instead of plastics & vinyls which expand & shrink more with the hot/cold weather cycles. Also a lot of vinyl flooring is made in layers which expand/contract at different rates which can cause bubbling.
Ours in the Safari has been down 15 years now and it looks as good now as it did day one. Our old Globetrotter’s is probably hanging in there too - but we don’t have it any more to report on.
Shari
Replacing original flooring with vinyl plank flooring Team Hardy Repairing/Replacing Floor &/or Frame 23 10-26-2019 07:45 PM
Flooring ideas ALANSD Floor Finishes 47 02-25-2012 01:20 PM
Great Flooring Price melprice Floor Finishes 0 07-08-2002 08:48 PM
Replacing the flooring - 61 Bambi 61BambiCanada Upholstery, Blinds, Walls & Interior Finishes 2 06-10-2002 07:59 AM
Removing old flooring and enhancing exisiting floor? Andy R Floor Finishes 4 05-18-2002 12:56 PM
