Old 06-04-2013, 02:24 PM   #1
1988 25' Excella
Trumbull , Connecticut
Floor Rot
Hello. Looking for a recomendation for material to put on small floor rot area to patch it up. I read that there are epoxy materials that can be painted on and will retard the spread of rot and where to buy them. Any ideas?
Happy camping nm1oqrz
nm1oqrz is offline   Reply With Quote
Old 06-04-2013, 02:30 PM   #2
Steve Bryant's Avatar
1991 34' Limited
Wichita , Kansas
There are some wood stabilizer products that are good, but I can't recommend a specific brand. What have you done to verify that the rot is limited to a small area? I think that you need to really know if you are just up against a mouse or a mammoth or maybe something in between regarding the rot.
Steve
Steve Bryant is offline   Reply With Quote
Old 06-04-2013, 03:15 PM   #3
Frank's Trailer Works's Avatar
Baltimore , Maryland
Very good advice from Steve Bryant...
Frank's Trailer Works is offline   Reply With Quote
Old 06-04-2013, 11:11 PM   #4
1991 34' Limited
Wichita , Kansas
nm1oqrz,
If you want to take a look at some of my experiences with floor rot and leaks, take a look at this thread http://www.airforums.com/forums/f36/...-85517-20.html.
Steve
Old 06-04-2013, 11:53 PM   #5
pinkflamingoes's Avatar
1967 24' Tradewind
Alameda , California
Images: 38
Send a message via AIM to pinkflamingoes Send a message via Yahoo to pinkflamingoes
There is stuff called Restor-it (NOT Restor-a-Finish) which comes in two parts. It is used to treat existing and immediately stop rot in wood. It's even used for historic monuments to treat and patch (separate putty) wood.
It is clear, the consistency of water, mix in two equal parts and apply very liberally. It is also $60 a gallon.
But cutting out ALL rotted areas completely and replacing with new is the thing to do. The last thing you want is to have to get to that floor again. Very important that you cut out the bad.
You could paint restor-it on the old flooring that you are leaving in, that is not rotted. Also treat the edges of newly cut floor. But cut out rotted and replace with new...really important.
www.restor-it.com
Carried at Ace Hardware stores and other dealers on the site.
"Let's look Death in the face and say, 'Whatever man.'"
~ Hurley
ingrid
1967 24' Tradewind #19104 ~ Forums #4449
pinkflamingoes is offline   Reply With Quote
Old 06-05-2013, 04:04 AM   #6
"Cloudsplitter"
2003 25' Classic
Thumbs up
This little gizmo helps a lot.....
