Normally, the first thing I would do in troubleshooting is to look at the instrumentation itself and how it is being used to confirm 1) it is working correctly, 2) it is being used correctly, and 3) the environment in which it is working is not interfering with or fooling the detectors.
Sometimes the instruments or tests we perform can give false readings, and so we always have to first ask, is there really a problem, and if so, is it with the equipment or with the actual test subject?
Without knowing exactly how your moisture detector works, I would see if another detector, preferably one that works differently, also senses the moisture, or if there is something that could be throwing it off, like, i dunno, a water line, a refrigerator defroster, an aluminum reflection...?
The point being, that before I start taking apart the trailer, I would try to understand why the detector is acting the way it is first. Could be right, or it could be wrong.
