Old 02-05-2023, 07:28 AM   #1
2000 25' Safari
Ishpeming , Michigan
Carpeting to Hardwood?
2000 Safari...Did they come carpeted from factory? Would installing hardwood increase value? Cost? Thoughts advice appretiated.
Letch is offline   Reply With Quote
Old 02-05-2023, 07:37 AM   #2
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
My guess is it came with carpet but am not sure. I think hardwood for carpet is a significant upgrade in terms of using the trailer. We have hardwood flooring in one of our older trailers and a floating vinyl plank in the other. We hated the carpeting. Do check around the edges and in the storage compartments and where ever you can to see if there is water damage to the subfloor under the flooring. I would think the value of the hardwood is going to depend upon how nice it looks and how well it is installed.
Old 02-05-2023, 09:23 AM   #3
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Russellville , earth
Dumping carpet for laminated wood floors is a no brainer for my money. Much easier to cope with the dirt you track in. Throw rugs can be added were desired.
Rodney
Visit my photography and painting website
https://rooseveltfineart.com
Instagram is r.w.roosevelt
Boondocker is offline   Reply With Quote
Old 02-05-2023, 03:11 PM   #4
2000 25' Safari
If I install laminate .what is the floating material?I'm not doing to myself so would help when I speak with installer.may try some of prep work like tearing out carpet.
Old 02-05-2023, 03:28 PM   #5
"Cloudsplitter"
A floating floor is not glued or physically attached to the substrate.
It has an opportunity to 'float' so well it can float up real good.
We have carpet...SWMBO loves it and I have no opinion.
Although I did rip it up for all outside storage compartments.
BTW all traffic areas are under runners.
ID:	427829   Click image for larger version
Old 02-08-2023, 06:32 AM   #6
Superannuated Member
Aironius's Avatar
2001 19' Bambi
Beaver Lake , Arkansas
You will probably find that he carpet is under everything, usually put in before the furniture. I can't figure out how to send you a link, but search "Bambi Carpet Removal project 2022" in this forum for my post about removing carpet in my '01 Bambi. I replaced it with Supercore Xtreme vinyl stone composite planks and it worked out well. My research led me to it for temperature stability (very little expansion / contraction). You can choose to remove the cabinets as I did, or cut around them. I removed the cabinets that would have required fancy cuts around the edges and left the ones I could lay planks up to and slip them under the edge. The important thing is that you have good subfloor, no rot or warping. Mine was OK but I found some water leaks that the factory kindly included at no extra charge...
Aironius is offline   Reply With Quote
Old 02-08-2023, 08:55 AM   #7
2000 25' Safari
Woodbine , Georgia
As the owner of a 2000 25' Safari-it did come with carpet. When I replaced the carpet with vinyl plank flooring, I removed the twin beds, gaucho, and the front corner cabinet as carpet was under all these items and installed the flooring. Having access made installing the flooring so much easier as it took less cutting and longer runs of the flooring. Reassemble was easy. I don't see how replacing 23 year old carpet with flooring affects the value as carpet use is way down today.
gamakai is offline   Reply With Quote
Removing carpeting, replacing with ? 99Limited34 Floor Finishes 7 04-10-2010 06:36 PM
Out with the carpeting? missysanford Floor Finishes 4 06-01-2008 04:19 PM
How do you protect carpeting in 22' AS? MyParadise 2002 - 2005 International 17 03-01-2008 07:24 AM
has anyone used sisal carpeting for the floor? zoeb nj Repairing/Replacing Floor &/or Frame 0 08-31-2005 03:58 PM
Carpeting spinolio Floor Finishes 2 05-06-2003 11:47 AM
