C-Channel, subfloor, and outrigger question
Hi Airfourms!
I'm pretty deep into a renovation of a 68 ambassador. I have a question regarding the standard construction of Airstreams.
Are the bolts that connect the C-Channel to the subfloor supposed to secure to the outriggers? In other words, does the bolt go through the c-channel, subfloor, and then get secured to the frame at the edge of an outrigger? Or is the c-channel only typically connected to the subfloor and then the subfloor to the frame via all the elevator bolts?
The reason I'm asking is that when I took out my subfloor (minus what I left for support in the C-Channel), I noticed that the curbside and roadside of the c-channel are sitting on the outriggers differently. On the curbside, the subfloor extends flush to the edge of the outriggers, and it appears that the bolts are secured to the outriggers. On the roadside, the subfloor and c-channel extend an inch beyond the outriggers. The bolts seem to be only going through the subfloor in most places. In some places, there's a half hole drilled just on the edge of the outrigger but not entirely through it. Some of the bolts seem to sit in these holes as if they were meant to connect to the outrigger. Is this just evidence of a botched reno job (it does look like the trailer had previous work done)?
To note: I braced the shell using a good amount of 2*4s to keep the shell from falling and also to keep it from bowing out. I could understand if the shell bowed out an inch while I was taking out the subfloor, but I noticed this long before I had the majority of it out.
Thanks for the feedback!
