11-24-2017, 06:25 AM
#21
2017 23' International
Austin
Originally Posted by tbaugh
I have the same problem in a 27 fc 2017. Jackson center found the leak in the pluming to the outside shower. They are going to take two weeks to remove everything on the floor and replace all the flooring. Will also check every thing out be for re assemble.
question for you on that 2 weeks--- do they have some sort of rain tent that they put it in to see if thats the root cause ? I would think you would have to set that up the right way to get it figured out.
11-24-2017, 06:40 AM
#22
2023 16' Basecamp
Chgo. N.W. Burb's
Leak
They have a Rain booth that all trailers go thru during assy. and they have a portable rain test unit.
Appt. for JC might be Feb. They have the experience and have probably seen this leak before and know how to fix. Have been there twice and have very good result's.
11-24-2017, 07:41 AM
#23
1981 31' Excella II
New Market
, Alabama
Problem is with the floor coverings is that they hide leaks. Frame is first, then insulation, then floor, then linoleum. Water that gets in stays hidden so you don't see it in a rain test. The linoleum is not plastic so eventually water comes through as a stain.
Perry
11-24-2017, 08:04 AM
#24
Austin
Perry
Perry thanks , I agree that is the problem for sure.
I have been also doing some research and doing some PM with some members that came forth with suggestions.
I am not sure if I mentioned this, but this unit is a 2017 that I purchased in February 2017 from Orlando RV. so it is only 9 months old . Orlando RV did a great job when I picked it up, it was an out of town purchase, they are a good dealership I think.
What I am trying to do now is figure out which of these options are best:
1) trade my unit back to dealer I bought it from, let them do the warranty work and trade up into a new larger unit .
2) get Jackson Center scheduled, although I am not sure if they will pay the freight for me to send it up there.
I have been trying to find the leak for several days now, I like to try to fix things myself.
Has anyone else on this forum bought a new unit with a leak and dealt with a similar trade in issue vs Jackson Center repair ?
thanks all for your help
The older I get , the better I was.
11-24-2017, 09:09 AM
#25
Tampa
Originally Posted by troubadour1
I bought it from a dealership in Florida and emailed to maybe make a trade up into a newer unit but they aren’t being super generous on the trade value.
You'll find that no dealer gives you a fair trade in value. You're much better selling it on RV Trader. However, you can't really sell it privately until you fix the floor.
I second the vote to take it to JC. Get it done right.
Flying? Did you plan to leave your tow vehicle there?
11-24-2017, 09:28 AM
#26
Austin
I was considering leaving the TV there if they think it will be more than a couple days to repair.
its a 1,236 mile one-way trip to JC from Austin, TX.
11-24-2017, 10:55 AM
#27
2010 25' FB Flying Cloud
Powell
, Ohio
I’m not sure how they found the problem. I had found the water on the water line from the pump. With every thing out there will be a through inspection which I will be there for.
11-24-2017, 11:21 AM
#28
2012 25' FB Eddie Bauer
Virginia Beach
, Virginia
You seem ready to trade up.
That being the case, take it to JC and have EVERY LITTLE THING fixed. Doing the floor repair is a big job that most busy dealers don't like. It ties up a bay for days and they have to wait for JC to reimburse them. List your current unit on craigslist, etc. Be very honest because it will be better than new after it is fixed and thoroughly checked out. Insist that repair department does a pressure test to detect ALL leaks... air pumped inside via fan vent while soapy water is sprayed over the body and seam by seam, rivet by rivet is checked. Plumbing pressure test too.
Buy a new unit without a trade, but get it from a dealer who will have a service tech show you how to use a moisture meter... along with other preventative maintenance chores. I am actually NOT a member of WBCCI but most units have regular maintenance rallies where you can learn a lot of handy skills. Consider joining.
Paula
11-24-2017, 06:08 PM
#29
1981 31' Excella II
New Market
, Alabama
I am with the others. Take it to JC and let them fix it. They might let you watch to find out what caused the leak in the first place then you will know how to fix it when it happens again.
Get a moisture alarm. I think sonin makes one that has prongs that go through the floor and sounds when it senses wetness.
Perry
Perry
11-24-2017, 06:53 PM
#30
Jim J
2014 30' Flying Cloud
Austin
I think there are other dealers closer than Ohio who could perform the warranty work adequately. Ft Worth, Houston and Lubbock have dealers and another in Little Rock. Crain RV in Little Rock has the leak detection equipment to find leaks.
I understand and share your frustration with our local dealer. They have had the parts I needed and the service and parts people have given me some good advice from time to time when doing my own repairs.
11-25-2017, 05:32 AM
#31
Austin
Thanks! We almost beat Duke last night so anything is possible. Are you familiar with
http://www.northdallasrv.com/ I read some favorable about them on this forum. They don’t sell AS and only do repairs. I am going to call their service department manager on Monday just to check them out and then make a decision. I’m trying to look at this as part of the adventure of owning an Airstream. I looked into buying for years so kind of knew some stuff like this might happen. And am grateful for this forum what a bunch of fellow addicts!!
11-25-2017, 06:20 AM
#32
Austin
Ok here are a few pics. I’m trying to explain my process on this leak search. First pic you see where the pump is and where the damage is. It’s the Airstream floor plan.
Second and 3rd pics are the pipes that come off the pump. But I ran the water for 15 minutes off the pump with only freshwater in tank and no city water and there is Nonleakage. But.... look at the pipe pics. See that wood?? It had taken water it looks like in past.
I’m going to hook up to my city connection but it’s quite possible I went to a hi pressure area and my water pressure regulator is messed up.
11-25-2017, 06:31 AM
#33
Austin
One more pic from before of the damaged linoleum
11-25-2017, 06:34 AM
#34
2021 30' Globetrotter
East Northport
, New York
Did your turn on the water heater as well? That would add pressure. I noticed when I winterized my 23FB that with the water heater bypassed there was very little pressure on the hot side piping.
James
11-25-2017, 06:36 AM
#35
Austin
Black floor spots on linoleum
[ATTACH]299751
Pic of closet floor from farther away (where pump is)
11-25-2017, 06:39 AM
#36
Austin
Will do that now. Electric or gas matter?
11-25-2017, 06:42 AM
#37
2018 28' Flying Cloud
Kaleden (near Penticton)
, British Columbia
Your water pump has a threaded connection like this photo. I had a intermittent leak at this threaded connection in my bathroom. Make sure nut is tight. Put lots of paper towels down to help where the leak/drip might be coming from.
11-25-2017, 06:46 AM
#38
East Northport
, New York
I would think gas would get you up to temp faster.
James
11-25-2017, 06:50 AM
#39
Austin
Thanks Roxy-- I'm really intrigued what makes a leak "intermittent. " I don't want to tighten anything until I figure it out to make 100% sure I find the culprit. Intermittency would have t be due to either heat or gravity (angle ) I would think??
11-25-2017, 06:56 AM
#40
, British Columbia
In my case it was high city water pressure and it wasn't even that high. Maybe 65 psi. Of course the trailer water pressure regulator should take care of the high pressure condition but didn't. It is hard to say exactly what conditions would cause the drip. Maybe flushing the toilet. Probably a combination of things.
