Old 09-16-2020, 12:13 PM   #1
Marshfield , Alaska
Argosy rear end main rail frame repair
During the process of pulling apart the rear end to replace the rotten rear cross member, I discovered a fairly large split in the main frame rail. Behind the axel just under the battery box. May have been from water damage or even a battery leak. Does anyone have advise for the best way to go about the repair? It is a 74 Agosy 22.Click image for larger version
ID:	378778Click image for larger version
thearkArgosy is offline   Reply With Quote
Old 09-16-2020, 12:49 PM   #2
1972 Argosy 24
Ann Arbor , Michigan
Ez weld in a new pice just let a welder do it thay will know what to do ez
1972 is offline   Reply With Quote
Old 09-16-2020, 05:05 PM   #3
Marshfield , Alaska
Would a welder normally weld in a patch to the rail or cut it out an weld a new piece in?
Drilled 1/8Ē bolt hole in main frame rail: how bad did I screw up my frame? zen_stream Repairing/Replacing Floor &/or Frame 7 06-08-2020 12:21 PM
Front End Separation? Advice sought for front end skin repair. Re-Pete Ribs, Skins & Rivets 22 05-16-2020 10:08 PM
Rub Rail, Rub Rail 'where art thou?' Radman Clearcoat, Exterior Paint & Trim 18 08-09-2017 08:27 PM
Argosy belt line/rub rail end caps bkahler Argosy Motorhomes 3 10-12-2012 06:01 PM
shop repair of 1970s rear frame separation (non elephant ears repair) RV shop review simonhanbury Repairing/Replacing Floor &/or Frame 49 06-24-2008 09:16 AM
