Old 01-22-2021, 08:28 AM   #1
Totoro's Avatar
Huntington , West Virginia
79 Safari surprising
I am in the process of cleaning out the prior owners Bamboo flooring. I was surprised to see that the first and second pieces of plywood at the front of the trailer share a seam that runs right down the first strip of bolts. In other words, the first row of bolts donít run through any plywood. They are between the first sheets. Iím not sure how this provides any structural integrity, but here it is, 2021, and aside from a couple of small soft spots, the floor is surprisingly stable. Has anyone else made this observation?
Totoro is offline   Reply With Quote
Old 01-22-2021, 06:36 PM   #2
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
1969 21' Globetrotter
Conifer , Colorado
Certainly strange. I suspect there are rows of elevator bolts (flat heads) at each cross member which are about 24" apart in the frame. There may be other plywood seams in the floor that are not right on top of a cross member. Maybe someone figured the head of the bolt is big enough to clamp both pieces of plywood. Maybe the answer is visible if you could see the frame with the belly pan down.
David
WBCCI #8607 VAC Region 11
KnowledgeBase trailer renovation threads: 69 Globetrotter, 76 Sovereign, 75 Overlander, 66 Trade Wind Such fun !
Old 01-22-2021, 09:14 PM   #3
1970 23' Safari
Marion , New York
The elevator bolts are the same way in my '70 Safari. The head of the bolt straddles both sheets of plywood at the seams. What gives the seam strength is the plywood splice underneath. It is a six inch wide strip of wood that is glued and screwed to both edges of the floor sheets and rests on a recessed cross member. The elevator bolts go through this splice and then are bolted to the cross member.
Name:	Cross member splice.jpg
DremStremer is offline   Reply With Quote
Old 01-23-2021, 06:18 AM   #4
Totoro's Avatar
Thanks for the pic. Iím curious to see if I have the same running under mine. I will say that I have spotted some metal zig zag looking joiners on the interior surface that seem to have been hammered in between the two sheets. If I was at home I would post a pic.
Old 01-23-2021, 07:08 AM   #5
1970 23' Safari
Marion , New York
I found those zig zag joiners as well, but they were only between the two front sheets of plywood. Maybe because the first sheet spanned a greater distance to a cross member than the rest.
Old 01-23-2021, 07:20 AM   #6
1966 22' Safari
Fredericksburg , Texas
Iíve used metal corrugated splice ties before, but in light applications. Not in structural plywood. Our original floor in the 55 had those, but most were rusted through making them useless. When I replaced the floor, I used wooden biscuits. Same principle but wonít rust. So far, so good. Good luck
Bubba L is offline   Reply With Quote
Old 01-23-2021, 11:46 AM   #7
Totoro's Avatar
David
As I get more out, things should begin to reveal themselves. Thanks
Old 01-23-2021, 11:48 AM   #8
Totoro's Avatar
Thanks. I will consider those once I can see the underneath.
Old 01-23-2021, 11:51 AM   #9
Sag Harbor , New York
. . . When I replaced the floor, I used wooden biscuits. Same principle but won’t rust. So far, so good. Good luck
Also . . . seating each biscuit in both holes with liberal WEST epoxy makes the plywood edge butt-joint quite strong FWIW. A bit messy though . . . . . .
Old 01-26-2021, 04:26 AM   #10
Totoro's Avatar
Here is another interesting find. There seem to be some sort of heavy nail going through a portion of the plywood. Click image for larger version
Old 01-26-2021, 06:50 AM   #11
1970 23' Safari
Marion , New York
Those are actually the elevator bolts that attach the plywood to the cross members. However, it is odd they are not centered on the seam of the two sheets. In my previous reply picture you can see the other end of the bolts going through the cross member.
Old 01-27-2021, 12:12 PM   #12
Totoro's Avatar
Getting down to the nitty gritty with this floor removal. I got back to the wheel well and it appears that it will need to be removed in order to get to the wood underneath. Iím wondering how it is attached to the bottom of the wheel well. I donít see any bolts running through the edge of aluminum which surrounds it. In the meantime, I plan to cut around it closely to remove the floor, as I donít want the interior exposed until I am closer to replacing the floor.
Old 01-27-2021, 12:29 PM   #13
Totoro's Avatar
You are correct. I thought they were some kind of nail, at first, but then they turned out to have threads.
Old 01-29-2021, 06:18 PM   #14
Totoro's Avatar
Iíve decided to closely cut the subfloor around the fender wells and not remove the wood strip that remains in that channel. There is frame support(right up against) all around the fender wells, which should be more than adequate for subfloor support. Also, upon closer inspection, the plastic fender well provides no support for the shell. In other words, the frame portion that supports the fender well will also support the new subfloor. I was also pleasantly surprised that the frame was in surprisingly good shape. The only metal work will be the outrigger slots that hold the steps.
Surprising Fuel Savings at 55 mph Phoenix Tow Vehicles 64 01-01-2013 03:38 PM
Safari 19' vs Safari 22' michael165 2005 - 2010 Safari 15 06-04-2007 06:02 AM
On a safari for our Safari 3DogNight 2007 Safari SE 10 12-21-2006 12:54 AM
Doing research-19' Bambi-Safari OR 23' Safari-WHY? ernesto ca Member Introductions 9 04-06-2006 06:33 AM
