Old 07-21-2020, 06:16 AM   #401
wcronin4's Avatar
1978 31' Sovereign
New Smyrna Beach , Florida
If I had a nickel for every time I said “Rah Roh” on this project... My son who is a master surfboard builder said to me a couple of years ago that the sign of a true craftsman is how well they hide their mistakes.
When you consider that we are amateurs pursuing a hobby, doing things for the first time or things we don’t do often, mistakes and miscues are going to happen. So far most of mine have been correctable. But I admit to praying that I haven’t overlooked a big issue.
Bill
Keeping Faith
____________________________________
My Project thread
https://www.airforums.com/forums/f22...ff-191141.html
wcronin4 is offline   Reply With Quote
Old 07-21-2020, 02:13 PM   #402
1970 29' Ambassador
Beautiful Santa Rosa , California
Hi Bill,
Thanks for the reply, and also the perspective! My next steps (buttoning the trailer back up and starting on the windows) are a little intimidating to me, so I am going more slowly than I normally would, and spending a lot of time just staring at the area I am about to be working on... I am very grateful to have this forum as my main resource. So much support comes from here in both current posts and threads of others. It is amazing, and softens that aspect of not having done these things before :-)
California David
2002sheds is offline   Reply With Quote
Old 07-21-2020, 04:20 PM   #403
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Even those of us who've done it once, hesitate when we have to do it again. We're fixing soft floor in our rear bathroom, and buttoning things back up now, but we've changed how we hung the black tank back up and supported it. We'll also probably have to cut down some decorative elements and cabinets as we place them back into the bathroom as we put a little thicker flooring in there this time around. I think nothing ever goes back together exactly as it came out!
Continue to take pictures as you put things in. Hopefully you won't need to use them as we did!
Kay
Old 07-22-2020, 10:40 AM   #404
1970 29' Ambassador
Hi Kay,
Thanks for your response -- it is good to get your perspective! I had not been taking as many photos as I should have, and that penalized me when time passed between progress, I am now documenting pretty much every step because, well, my memory is not what it used to be :-)
I will definitely refer back to your Little Girl thread more than once as I proceed. The way you guys handled the interior walls is brilliant, in my opinion.
Thanks Again,
California David
Old 07-23-2020, 07:21 PM   #405
1970 29' Ambassador
Which one first?
Hi All,
Well, the buttoning process has begun, although I may have already Made a mistake.
The C (U?) channel below the rear access door is about 3/4 inch higher than the subfloor, even after making certain that the sag was taken out of the very back before beginning to attach the “sandwich”.
The C Channel on the sides are also lifted, although not as much. I initially thought it would be best to Start with bolting together the sandwich that includes the rear hold down, etc., but now I am wondering if I will be better off working my way around the corners and then finally attach the very back end.
Thoughts?
California David
Old 07-23-2020, 07:43 PM   #406
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
I might try putting a floor jack, or a screw jack, under each frame rail at the rear of the trailer. Carefully and slowly jack the trailer frame rails up until the subfloor reaches the C channel. Then bolt the "sandwich" together. We had to jack up our frame rails about an inch to close that gap. Then we bolted it all together.
The body holds the frame up, and the frame holds the body up. Semi-monocoque construction Airstream calls it.
Colorado David
WBCCI #8607
VAC Region 11
Link to my 1975 Overlander Improvement Journal:
https://www.airforums.com/forums/f17...ml#post2053792
Link to our 1976 Renovation Project:
https://www.airforums.com/forums/f221...ct-202081.html
dbj216 is online now   Reply With Quote
Old 07-23-2020, 11:18 PM   #407
1970 29' Ambassador
Hi David,
As usual, a great suggestion! I have jacks under the two frame rails already, but I stopped jacking when the floor became “flat” front to back, and level side to side. I didn’t take into account the fact that, even after being attached, the shell and frame will settle back into position. Thanks!
Once both frame members are raised enough, will it matter if I “button” from the sides or rear first?
California David
Old 07-24-2020, 01:31 PM   #408
1970 29' Ambassador
Buttoning up...
Hi All,
Exciting day today, as progress is being made on the re-attachment of the subfloor-C channel connection. Pics below include the fasteners (both elevator bolts and trailer floor bolts are being used), and also the first section of subfloor after cinching... the marks in the tops of the installed elevator bolts are from the use of a 5 pound hammer and the business end of a nail puller, as I "bammed" them into their seats.
California David
Name:	Airstream floor fasteners side view.jpg
ID:	373841   Click image for larger version
Name:	Airstream subfloor fasteners top view.jpg
Name:	Airstream rear  curb side subfloor.jpg
ID:	373843   Click image for larger version
Name:	Airstream curb side subfloor inside.jpg
Old 07-24-2020, 07:02 PM   #409
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
It certainly looks well attached. Maybe you got that gap at the rear closed up with your jacks. Normally the body is placed on the frame and subfloor from the top down. like using a hoist and gantry. Us guys to don't remove the body gotta bring the frame up to position. Then bolt the two tight with the plywood in-between.
Colorado David
WBCCI #8607
VAC Region 11
Old 07-24-2020, 09:06 PM   #410
1970 29' Ambassador
It's buttoned up, so you better get the party started!
Hi Colorado David,
Thanks for your reply! The sandwich "has been made"! I did jack up the frame as you had suggested -- that helped a great deal. Then, between using trailer floor screws and elevator bolts, I was able to secure the U Channel very securely to the frame and floor.
As you, Aerowood and others have written about, the vertical ribs in our coaches don't always make it to the U channel, nor is there a positive connection between the two (or three, where the frame intersects). I think this is weird, so I have cut some angled aluminum stock into short lengths, to act as L brackets. I have not yet determined the best method for connecting the L bracket to the rib, and am open to ideas :-)
I did get a rivet gun, and could potentially learn on these hidden pieces, but might aluminum rivets (the only ones I have) be too soft?
California David
Old 07-24-2020, 10:52 PM   #411
1980 24' Caravelle
vallejo , California
California Dave, glad to see your progress! ain't it great to see your own progress? i'm glad i had very little frame damage. look ford to see your progress. kurt
ke6gkv is offline   Reply With Quote
Old 07-25-2020, 05:38 AM   #412
mimiandrews's Avatar
1966 22' Safari
Hilltop Lakes , Texas
Thanks for the post. Any chance it was meant for a different thread? Or am I already to the point that I can't even remember asking about these things (definitely possible ?
dbj216 asked about that in Post #381. Sorry if I caused confusion.
Old 07-25-2020, 07:27 AM   #413
Iansk's Avatar
1977 31' Sovereign
Sunset Valley , Texas
Looking good David,
A couple suggestions if I may...
Not sure if you used lock nuts or lock washers but it’s a good idea to slightly bend the free end of the elevator bolts to eliminate any chance of the nuts coming loose. A couple whacks with that 5lb hammer should do it.
Use aluminum rivets with aluminum mandrels where you can’t buck. Galvanic corrosion and such... also, drilling out rivets with a steel mandrel is no joke, or it is a joke... either way, it sucks.
Ian
Iansk is offline   Reply With Quote
Old 07-25-2020, 07:29 AM   #414
Iansk's Avatar
1977 31' Sovereign
Oh yeah, I received your PM, holler when you want it.
Ian
Old 07-25-2020, 07:52 AM   #415
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
You need to use either AD rivets or bolts.
Old 07-25-2020, 10:14 AM   #416
1970 29' Ambassador
Hi All,
Thanks very much for the replies -- I am constantly amazed by the generosity of this crowd, and appreciate all of the comments and advice!
To answer as as much as I can, I will try to go in order...
Kurt, Thanks for the continued support. Cold beer is awaiting you, should you decide to make the trip to Wine Country !
Mimi, it most likely me that is confused -- something that seems to deepen with every passing year... :-)
Ian, thanks for the comments. That 5 pound hammer would indeed put a curve into the elevator bolts. I did use nylock nuts, so hopefully, that is enough. If not, the hammer is nearby... and I will PM you about that file as I get slightly closer.
Aerowood, Thanks, as always. I will heed your advice. If I cannot find AD rivets today I may seek out aluminum bolts for the ribs. The bolts through the C channel and floor are steel. The only galvanic corrosion that occurred the last time these connections were made (including a lot of steel bolts and screws) resulted in the rear hold down plate being sacrificed. It was nearly gone in several places. I plan to have zero (or nearly zero) water intrusion, and definitely am taking steps to eliminate the "reverse flashing" that has plagued these coaches. Hopefully, those measures (along with our somewhat drier climate) will slow down any corrosion from the few steel-to-aluminum connections that I will have.
Colorado David, Kay, Bill, and many others, thanks again for your guidance. This feels like a milestone, and it would have not been reached without the help of so many !
Last, I hope at least one of you picked up on the thread title's reference to a famous song by Pink. That song starts out "I'm... coming up, so you better get the party started"...
Have a great weekend!
California David
Old 07-25-2020, 07:42 PM   #417
Aerowood's Avatar
Arvada , Colorado
1970 New to us Ambassador reality check
AD rivets are very common, the Part Number you will need is MS20470AD5-x, x=the length in 16th inch increments. Genuine Aircraft Hardware is close to you in Santa Barbara.
Make sure you have a 5/32 470 rivet set.
You need to start using that rivet gun you have. It’s actually very simple and easy.
Old 07-25-2020, 08:20 PM   #418
1970 29' Ambassador
Hi Kip, All,
Well, when you are right, you are right. As I am uncovering the structure of this coach, I am finding more and more items that cause concern. Both rear corner ribs with the holes drilled into them standing loose next to the bucked rivets inside. Maybe those corner ribs are simply there for the furnishings, but then there wouldn't be all of the holes, exactly next to the bucked rivets.
I understand that a coach is different than a house, but my many years of remodeling make my brain ask how anyone would think that the load of the shell and ribs (not to mention air conditioner) should be borne by the last inch of quite thin aluminum shell, instead of a skeleton upon frame setup, like a building.
That, and the fairly large areas that were repair using Olympic rivets, and poorly at that... I just received a rivet gun and set from Yardstore. Looks like I will be getting plenty of use from it !
California David
Name:	Airstream street side rear corner rib loose.jpg
Old 07-26-2020, 08:17 AM   #419
Minno's Avatar
1972 31' Sovereign
Kip, what's an AD rivet? I asked Chris, and he said "anti-depressant". I don't think that's quite right.....
Kay
Old 07-26-2020, 08:20 AM   #420
Minno's Avatar
1972 31' Sovereign
CA David:
We had one of our wall panels riveted into the vent stack in the kitchen area when we took our trailer apart. I know your pain. We had no issues that you've had, though, with short ribs. We would do what you're doing and add lengtheners to tie in the structure. Loose is not good!
Kay
Another Reality Check! RLS Hitches, Couplers & Balls 24 09-23-2009 11:38 PM
Bathroom ABS repair-Reality check SilverHoot Upholstery, Blinds, Walls & Interior Finishes 1 07-21-2009 10:02 PM
POR15 reality check truckasaurus Repairing/Replacing Floor &/or Frame 20 06-07-2009 08:19 AM
Check , Check and Re-Check a new refer saga. thenewkid64 Refrigerators 13 06-24-2002 09:54 AM
