RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 01-24-2017, 10:18 PM   #1
Elm Mott , Arkansas
Help!
So I am looking to buy a travel trailer to gut and use for my boutique. I came across this listing and I need to know what questions to ask and what to look for. i don't know much about Airstreams yet, but from looking around, this seems really cheap so I assume there are problems. (I did message this person to see if it's still available and he did tell me that the date on the pic isn't correct. It's a 1976.)
ID:	278721   Click image for larger version
ID:	278723   Click image for larger version
teacake254 is offline   Reply With Quote
Old 01-25-2017, 08:29 AM   #2
1999 30' Excella 1000
small town , Maryland
Welcome to the forum teacake254. Nice pictures of the Argosy. Put new tires on and go, if it's not close to home. Since your going to gut and use as a boutique, all you need to worry about is the floor. Put down pergo or something similar to spruce it up. Make sure the air conditioner and heater are working. You might be able to sell the interior in the forum classifieds, to recoup some of your expenses. There is a similar trailer in Lucketts Va being used for displaying antiques inside. Good luck on your very cool boutique.
streaminwild is offline   Reply With Quote
Old 01-25-2017, 09:24 AM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
If you are going to gut it you only need look at the frame, skin, door, and floor.
It will have to be painted outside and that could go as high as $5,000 if sprayed.
You will not use the heater as it is noisy and poor distribution once the interior is out.
I would consider a heat pump AC and electric heat for ease and space considerations.
Once gutted put a man made flooring system in. Andersen is easy to work with is small spaces.
2004 Excursion 4x4
Old 01-26-2017, 09:08 AM   #4
Elm Mott , Arkansas
Thanks so much. This trailer is actually like 5 minutes from me so that's a plus!
Old 01-26-2017, 09:10 AM   #5
Elm Mott , Arkansas
Thanks! What about axles on these? That seems to be a common concern in the trailers in other threads. Also, for painting the outside, can any auto painting shop do that?
Old 01-26-2017, 09:29 AM   #6
BambiTex's Avatar
1955 22' Safari
1967 26' Overlander
Clear Lake Shores , Texas
I would think an auto body place could paint it.
You might consider split system A/C for low noise/current draw.
BambiTex is offline   Reply With Quote
Old 01-26-2017, 09:29 AM   #7
HowieE's Avatar
Images: 12
I had assumed it was going to be a fixed location.
If the trailer is going on the road and the axles are torsion type then will most likely need replacement. If the are spring type you are dealing with a much less expensive item and may not even need replacement.
2004 Excursion 4x4
Old 01-26-2017, 10:19 AM   #8
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Good Price. If you are gutting it post the interior parts, someone may be able to use them.
help, help, help. new to it all. ohwally Member Introductions 5 08-24-2008 05:18 PM
HELP HELP HELP!! Lug nuts & Stems Chitown AirStreamers Wheels, Hubs & Bearings 4 08-18-2008 05:41 PM
Hot Water Heater HELP HELP HELP!!! Igor68 Water Heaters, Filters & Pumps 2 06-22-2006 09:07 PM
Help Help Help!!! rebel beck 1974 - 1979 Sovereign 9 01-07-2006 04:00 PM
