12-22-2020, 05:56 PM
#121
1986 34' Limited
1975 27' Overlander
1969 21' Globetrotter
Conifer
Nice. Does it come with a wall mounted thermostat?
Smart alec David
WBCCI #8607 VAC Region 11
KnowledgeBase trailer renovation threads: 69 Globetrotter, 76 Sovereign, 75 Overlander, 66 Trade Wind Such fun !
01-11-2021, 01:54 PM
#122
1972 29' Ambassador
saint louis
, Missouri
started putting the interior skins in. that reminds me I need to order more clecos
01-11-2021, 06:34 PM
#123
1986 34' Limited
1975 27' Overlander
Conifer
Putting the inside skins back on is a major undertaking. I've never had to take them down or of course put them back up. But I'm told it is quite a job. Yep, sheet metal clamps (Clecos) are a necessity to do the job.
David
01-12-2021, 07:52 AM
#124
1972 29' Ambassador
saint louis
, Missouri
I thought it would be a lot more difficult. I wouldn't want to attempt installing a full 12' length. so i'm keeping the sheets at manageable lengths. the longest piece so far is about 8'. I will probably go with longer lengths on the lower section where I don't have the curve. here is a picture of my son using his head to help hold sheet in place. ha
02-10-2021, 08:47 AM
#125
1972 29' Ambassador
saint louis
, Missouri
almost finished with the new interior skins. I need to drill and run wires for rear camera and wire up the running gear and then I can put the last 2 pieces in place. it's all down hill from here. right? ha!
02-10-2021, 08:54 AM
#126
1962 28' Ambassador
1961 19' Globetrotter
Mesa
Here you go
Hittenstiehl
02-10-2021, 08:55 AM
#127
1972 31' Sovereign
Lexington
Ummm, ya sure. Downhill.....
More on the order of exciting and frustrating all at the same time! Just doesn't seem to go fast enough.
BUT, you'll get there! The grunge stuff is done.
Kay
03-04-2021, 07:54 AM
#128
1972 29' Ambassador
saint louis
, Missouri
end caps and wheel wells complete. next step is to layout bathroom and tank placement
03-04-2021, 06:09 PM
#129
1986 34' Limited
1975 27' Overlander
Conifer
You're making progress for sure. Bathroom layouts are a challenge sometimes. I wonder if you are changing to a rear bedroom and a mid bath layout? I kept my 75 Overlander 27' rear bath. A rear bath is bigger that a mid bath, but a mid bath allows more privacy in the bedroom, especially of other family members are traveling with on the trip.
I'm changing my son's 69 Globetrotter 21' to a rear bed (oversized twin is all that will fit) and a mid bath. The new "powder room" half bath will be bigger and nicer than the factory fiberglass wet bath affair, but it takes up floor space. I lose 9" of galley counter space, but I think it will be worth it. The trailer will sleep three comfortably when done. Two in front on the convertible dinette, and one in the back. Everyone will have access to the bathroom if needed.
David
03-05-2021, 07:25 AM
#130
1972 29' Ambassador
saint louis
, Missouri
yes we are moving the rear bath to a mid bath
05-12-2021, 12:55 PM
#131
1972 29' Ambassador
saint louis
, Missouri
cleaned up and painted window frame. going with a black and silver color scheme so we painted frames a black semi gloss. it is nice having the windows fully operational again. finished framing out bathroom walls and started layout the rest of the interior.
05-13-2021, 04:54 AM
#132
1956 22' Safari
1962 28' Ambassador
Williston
, Vermont
The blacked out frames looks nice. A very clean, distinctive look.
Curious what you are using for framing, steel or aluminum? And what gauge/thickness ? - Mark
05-13-2021, 07:44 AM
#133
1972 29' Ambassador
saint louis
, Missouri
the bathroom walls are 2-1/2" 25ga steel. i'm just using it on the bathroom walls to hide the plumbing. for the cabinet frames i will be using aluminum angle. i have some salvaged aluminum floor base and outdoor bleacher cross braces. i will post photos of that when i get further along
06-02-2021, 07:22 AM
#134
1972 29' Ambassador
saint louis
, Missouri
installed the chimney for wood burning stove. this should be the last hole i need to cut into roof. will probably add another coat of roof paint to seal it all up. also going to get the top coat sealer. as you can see from photos the roof has stained quite a bit
09-08-2021, 02:25 PM
#135
1972 29' Ambassador
Ridgecrest
How did your Reno go?
09-09-2021, 08:14 PM
#136
Still Dreaming
1971 29' Ambassador
Sulphur Springs
Having fallen down the same rabbit hole, may I observe that you have not purchased a mobile camping outfit, but rather, a consuming and expensive construction hobby.
Have fun and don't get hurt! Cheers, Manning
09-18-2021, 02:41 PM
#137
1972 29' Ambassador
saint louis
, Missouri
got the outside all finished up. eventually new fabric on the old awnings. haven't worked on hub cabs yet. now to start working on the inside.
09-18-2021, 05:03 PM
#138
1986 34' Limited
1975 27' Overlander
Conifer
It appears nicely polished. A shiny Airstream always draws attention. I bet you will find the interior renovation will be the most time consuming. At least it is for me.
David
09-20-2021, 10:02 AM
#139
1972 29' Ambassador
saint louis
, Missouri
the outside was very time consuming. removing old caulk, rebuilding windows, polishing and working around the weather. i didn't think it would ever be done. i have never worked on an airstream before so it was all new to me. the interior stuff like building cabinets i am familiar with. hopefully it will go much quicker
09-21-2021, 07:42 AM
#140
1972 31' Sovereign
Lexington
We spent 4 years with the trailer up on cement blocks in the back yard just to get her to the point that insurance would cover her on the road: "75% functional and 100% roadworthy", then another 2 years to finish cabinetry. And that was without polishing! Worth every minute. Takes maintenance every year too. Now we have a new interior aluminum segmented headliner from Colin Hyde to install in the spring. Just have to figure out how to do it....
Kay
