Old 08-07-2017, 08:25 PM   #1
Wichita , Kansas
Which Airstream vintage model?
Hi, Iím new to the Airstream Forum. I donít have an Airstream at this time but Iím doing some research to help me narrow down all the models there are. I havenít decided whether I want to purchase a more recent model or get into a shell-off restoration on an older model. Sunlight is a very important factor for me, especially as I plan to live and travel in it full-time. Ultimately, I want an Airstream travel trailer that is at least 27 feet long, doesnít have SOs, and has the most window and/or largest window openings. Which vintage models would you suggest I consider?
HighRoad is offline   Reply With Quote
Old 08-10-2017, 07:07 PM   #2
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Welcome High Road: Let me see if I can get a discussion going on what you might be looking for. You mention a couple of key requirements like "full time", > 27', lots of sunlight.
I might suggest you look for the 34', triple axle Classic, or Limited models. They started making them in 1983 and pretty much stopped regular production in or around 2008. We have a 86 Limited. You can find a couple of floor layouts for these models, e.g. twin beds or a double bed. Check on the Airstream.com website, archived documents.
I suggest the 34 Limited, maybe even as late as 2000. There are many examples for sale. Many are in darn good shape. You can always decorate to your tastes. There are always things to fix or make better on an old Airstream. The extra room in the 34 is a blessing for full timers. I recommend a 3/4 ton tow truck for a more secure experience in the mountains.
We really enjoy ours. We have had it since 05. Picture below.
Airstreams are nice ovens in the hot sun. The aluminum exterior gets pretty warm. We find we pull the blinds to lessen heat ingress inside. If we want sunshine, we step outside. Airstreams are best in temperate climates. Minnesota winters aren't made for Airstreams, and neither are Texas summers. Be prepared to travel where the weather suits your Airstream.
There, you may now get 50 more recommendations better than mine.
David
Name:	1407 Off To Denver (Small).jpg
Old 08-10-2017, 08:56 PM   #3
TheGreatleys's Avatar
1974 27' Overlander
Baltimore , Maryland
All of the Airstreams have great light. You'll probably end up choosing by size and availability rather than window configuration.
Later models have larger windows. You can look for a vintage model that has a solar dome and replace it with one of the popular Maxim skylights. I believe those were available on 60s and early 80s models.
TheGreatleys is offline   Reply With Quote
Dump Valves Which is back and which is grey? clicker187 Waste Systems, Tanks & Totes 8 02-21-2021 09:27 AM
Univolt internals - which fuse is which? barts Batteries, Univolts, Converters & Inverters 9 08-13-2017 09:18 AM
Heating and Air Cond. - Which wires are which? trekerboy Electrical - Systems, Generators, Batteries & Solar 12 08-09-2015 08:37 AM
Which tank is which? dejahardy13 Fresh Water Systems 8 09-24-2010 09:23 PM
Which switch is which or what 74Sovereign Electrical - Systems, Generators, Batteries & Solar 6 09-10-2002 08:55 AM
