Go Back   Airstream Forums > Airstream Community Forums > Dollars & Cents > Buyer Guidelines
Old 01-19-2017, 12:48 PM   #1
san jose , California
Inspection Upon Delivery
Hi, I am very excited to become owner of airstream 2015 flying Cloud 23 bunk.
this is my first time to own a trailer and its pre-owned one, I look for suggestion on inspection upon delivery. I got a generic version of inspection sheet, but thats not airstream specific one, very generic.
again, looking for any advice in terms of inspection on delivery day.
mikio is offline   Reply With Quote
Old 01-19-2017, 01:56 PM   #2
Boxite's Avatar
2008 22' Safari
Walk around the floors everywhere and check for "softness" indicating water leakage, especially around doors and bathroom beside shower and in front of sinks. Any squeaking or softness is bad.
Smell around refrigerator for ammonia smell = leaking refrigerant = big buck$
Check out the roof for damage and hail and the rear end for having backed into objects and tree limbs in campsites.
Operate the awning and confirm no damage or mildew and arms work properly.
Operate all windows and make certain they work properly.
Operate all appliances: furnace, AC, water heater, water-pump, stove, oven/microwave, TV, AM/FM and all lighting. Does the toilet operate properly? and hold water above the knife/flush valve? Does the water heater lamp illuminate then extinguish as the water heater heats up on propane?
Are the LPG hoses soft and flexible? or hardened and cracked? Are the LP tanks damaged? rusty? valves work ok?
Test the smoke detector, Carbon Monoxide detector and LPG detector.
Run water into the grey tank and then see if the knife valves work properly in the dump. (this might be a problem unless you're at a dump site for the black tank valve check.)
Test the brakes by operating them manually via the controller to see if the trailer will hold the Tow vehicle in-place against light application of power.
Be critical as if you're looking at it for defects for a friend....avoid your enthusiasm for your new toy.
Enjoy it.
Old 01-19-2017, 02:00 PM   #3
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Suggestion, inspect it before delivery and handing over check or cash. Buyer beware!
http://www.airforums.com/forums/f138...ist-43294.html
MICHAEL
Old 01-19-2017, 03:41 PM   #4
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Have an Aiurstream dealer inspect it. Worth spending a few bucks.
Pre Delivery Inspection scarletbison Sprinter and B-van Forum 15 11-14-2014 07:38 AM
2014 Serenity 28' - post delivery inspection westernjeep401 2011 - 2015 International 6 10-01-2014 06:35 AM
Pre-Delivery Inspection gastockman Sprinter and B-van Forum 44 08-14-2012 03:19 PM
New Unit Pre-Delivery Inspection Advice tomriley 2001 - 2005 Classic 6 02-23-2005 08:40 PM
once upon a midnight dreary, while i ... norbert Off Topic Forum 10 01-17-2004 07:31 AM
