Old 07-03-2022, 12:03 PM   #1
Airstream - Other
Crockett , Texas
Identity
Can you tell me what year this Land Yacht is? Nevever had so much trouble sending images. There down loaded but can't get them to send. The tag by the door is a Californian vin tag with DoH No. 29954. At the bottom of the tag.
ej110884 is offline   Reply With Quote
Old 07-03-2022, 12:26 PM   #2
Hittenstiehl's Avatar
1962 28' Ambassador
1961 19' Globetrotter
Mesa , Arizona
See if there is another number by the door. The department of housing tag is usually a state requirement regarding human occupation. The other number will be the identification number/vintage #. Of course if you can add the photo of the tags or the actual trailer people can help.
If you use the airforum app it is just like attaching a photo in text or as an attachment.
Hittenstiehl
Hittenstiehl is offline   Reply With Quote
Old 07-03-2022, 01:19 PM   #3
Airstream - Other
Crockett , Texas
There is another number above the first number. It is 187 on the tag.
Old 07-03-2022, 06:33 PM   #4
1962 28' Ambassador
Mesa , Arizona
Do you have a tag/label such as this on the curbside?
(This is an online example only)Click image for larger version
Hittenstiehl
Old 07-04-2022, 09:38 AM   #5
Airstream - Other
Crockett , Texas
The tag by the door has the california state seal on it and the numbers from the previous two post.
Old 07-04-2022, 09:45 AM   #6
1966 22' Safari
Fredericksburg , Texas
When figured out, posting pictures will narrow it down. Type of tail lights, number of end panel segments, type of windows and layout, and any other information to help ID. Unfortunately, my familiarity of Airstreams only goes up to about 1970. Good luck
Bubba L is offline   Reply With Quote
Old 07-04-2022, 01:03 PM   #7
1962 28' Ambassador
Mesa , Arizona
EJ the tag you are describing is not your Airstream data plate. It sounds like its the state (CA) applied plate regarding department of housing or occupancy of a trailer.
It is possible your Airsrteam blue of silver data plate is missing or removed, that is not uncommon. On vintage models they were by the door and nowhere else. Sometimes there is a different number on the frame but that's not the make or model.
Because of that (as Bubba said) you will need to figure out how to post a picture. Folks here can figure out what you have based on images of curbside, streetwise and rears in addition to interiors. You can also measure from bumper to ball and advise how long it is. Your length will be close to the model number especially with a vintage.
You'll get the attaching a photo part figured out and then folks will chime in on what you have.
Hittenstiehl
Old 07-04-2022, 09:46 PM   #8
Airstream - Other
Crockett , Texas
I have tried to post pictures but now I'm being told the file is two big. Is it possible I could email the pictures to you? I emailed them from my phone to Gmail and no issues.
Old 07-04-2022, 09:52 PM   #9
Airstream - Other
Crockett , Texas
If its not a rule or something can I just email the pictures to you? I'm being told now the files two big. its just four pictures. I emailed them from my phone to my self and there where no issues. You can upload them if you like till i finally have time to figure out what I'm doing wrong. I've posted pictures many times but this time I don't know.
Old 07-04-2022, 10:46 PM   #10
66Overlander's Avatar
1962 22' Safari
2016 30' Classic
Southeast , Michigan
Images: 41
The serial number on the plate near door can be decoded using this decoder . . . if the Airstream was made between 1959 and 1980:
https://www.airstream.com/wp-content...2020-06-16.pdf
Joe
WBCCI/VAC #702 & #6768
66Overlander is offline   Reply With Quote
Old 07-05-2022, 08:39 AM   #11
1962 28' Ambassador
Mesa , Arizona
EJ
Just resize or crop the photos a bit smaller and it should work.
(66 it's the department of housing plate that be has located)
Hittenstiehl
Old 07-05-2022, 08:57 AM   #12
1966 22' Safari
I sent a PM to ej110884 with my contact information. If he wants, he can send me the pictures and I will upload to this thread. Or, we can discuss and walk him through the process of uploading photos.
Old 07-05-2022, 09:09 AM   #13
Airstream - Other
Crockett , Texas
I did not receive your email address Bubba. My email address is ej110884@gmail.com. This traile appears to be vintage.
Old 07-05-2022, 09:28 AM   #14
1962 28' Ambassador
Mesa , Arizona
Thx Bubba sounds like it'll get figured out. I feel for folks when they're first trying to figure the forum out.
Hittenstiehl
Old 07-05-2022, 09:57 AM   #15
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
At various points in the past decades, some states replaced non-standard VIN tags with new ones to issue them a VIN which conformed with how they thought it should look. I've seen this with old bus conversions and some vintage cars. I wonder if your original tag was removed when the California tag was added, or perhaps the California tag was added because the original one was already gone.
Richard
11018
richard5933 is offline   Reply With Quote
Old 07-05-2022, 10:18 AM   #16
1966 22' Safari
These are the photos ej110884 wanted to post:
ID:	418976   Click image for larger version
ID:	418978   Click image for larger version
ID:	418980   Click image for larger version
Old 07-05-2022, 11:24 AM   #17
1962 28' Ambassador
Mesa , Arizona
Thanks Bubba that's fantastic! Yes that's the black department of housing tag I thought it was and it doesn't help.
66Overlander (and others) is going to be able to id this trailer based on the exterior accouterments and the style of that land yacht tag. That tag and placement of it will have only been used for certain years.
Identifying features are the number of rear panels, window placements (they dont look original), door in door, vent placement, slope of the rear.
I'm thinking late 50's (but I'm not at a desk top computer where I can look up archived images) but Joe has these things memorized and will inform us.
Hittenstiehl
Old 07-05-2022, 12:09 PM   #18
1966 22' Safari
Iím going to have to guess the first year for the Tradewind, 1960.
Old 07-05-2022, 12:36 PM   #19
Airstream - Other
Crockett , Texas
I appreciate your kind help Bubba L. My wife has all ways wanted a airstream and vintage makes it that much better. It's going to be a lot of fun for my wife and me doing a restoration. I hope someone out there can give us the year it was built. Thank you again.
Old 07-05-2022, 12:58 PM   #20
1962 28' Ambassador
Mesa , Arizona
EJ, glad Bubba was able to help with the photos. The Airstream historian, 66 Overlander, will finalize your ID for you.
Did you get a chance to measure from ball to bumper yet?
I agree with Bubba's time frame. May end up between 58 to 64. The end caps changed from 13 to 7 panel in 58ish and the door in door stopped in 64. The windows by the door should be jalousie but they've likely been changed. Ohio build I think.
Hittenstiehl
Identity of small floor duct flyflinger Furnaces, Heaters, Fireplaces & Air Conditioning 5 11-15-2009 06:53 PM
Identity please ? (name the trailer!) aircooled4 Vintage Kin 11 11-14-2009 04:31 PM
Identity problem help ? beelertank Member Introductions 10 11-10-2009 07:10 PM
'69 Caravel - Identity of Roof Vents Julison 1969-1971 Caravel 4 09-30-2005 09:17 AM
Identity Protection RV and Home FrankR Off Topic Forum 0 09-10-2002 09:26 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
