12-20-2022, 01:08 PM
2017 25' Flying Cloud
Celina
Airstreams in Classifieds with Frame-Body Separation. What to do?
Have started seeing used, recently built Airstreams advertised for sale on this forum that have obvious frame-body separation wrinkling at the front storage door lower corner(s).
Whats a person who is shopping for a used Airstream to do?
Go to the next ad?
Inform the advertiser he might have a problem selling?
Use the defect as a tool in negotiations?
Caveat Emptor?
2017 Ford F150 Lariat 3.5L EcoBoost w/Max Tow
FAA Certificated Remote (Drone) Pilot
Amateur Radio Extra Class N5EAS
Journeying America via the "Blue Highways"
-Be Curious, Not Judgemental…Walt Whitman-
12-20-2022, 04:16 PM
2019 27' Globetrotter
McHenry
You’re certainly within your right to question them about it and see if they’ve had Airstream repair the issue. It’s a pretty common occurrence and not a death sentence especially if the repair was done right. JC now has a “new” version of the fix noted on Ray Eklund’s thread (see post# 323).
I’ve got an appointment in June at JC to have ours repaired with the latest fix. Ours was done the first time back in October of 2020 before they came up with the more permanent repair.
Good luck with your search!
2019 27’ Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1000#
WBCCI# 10258
RETIRED!
12-20-2022, 08:05 PM
2013 27' FB International
El Dorado Hills
I'm not convinced this is even a problem. Two years ago noticed a dimple and a broken rivet on one side. Soon thereafter a short 1/2" crack appeared in the dimple. I removed the broken rivet and replaced it with a stout stainless steel screw. I placed a small piece of clear packing tape over the crack to prevent water intrusion and to monitor movement. Two years later, and about 10,000 miles, the tape is still intact and no more problems.
12-21-2022, 06:49 AM
2018 25' International
Slidell
, Louisiana
I was made aware of the issue very early on back in 2018 by other folks posting about panel creasing. Took a close look at ours and noticed very slight distortions beginning to appear. Over then next couple months it slightly increased so I switched to a much more forgiving weight distribution hitch design and setting and altered tire pressures. 25,000 miles later and the slight distortion has not changed.
Buyers do somehow need to be aware to look for this issue when purchasing trailers with the large front hatch openings for the years where this is a problem. Information is difficult to disseminate.....
12-21-2022, 07:20 AM
2020 Globetrotter 25 FBT
2020 25' Globetrotter
Wildwood
, Missouri
I have a dimple the same as described by BB above. You have to get the light just right to see it. It hasn’t changed in two years. I’ve decided no to pursue it with AS. I’m not convinced it’s going to get worse, or even be a problem.
2020 25GT FBT
2012 Toyota Tundra Dbl Cab, 5.7 4x4
Previous AS trailers: (04) 19’ Bambi, and (11) FC 23FB
12-21-2022, 09:42 AM
2013 31' Classic
billings
, Montana
Fix the problem …there several posts on thid
12-21-2022, 11:26 AM
palm beach gardens
I recommend Colin Hyde in Plattsburgh, NY for at least a call if not for a repair. He is very familar with this problem and very capable at most repairs as i have personally found out.
12-21-2022, 12:09 PM
2019 27' International
Rogers
, Arkansas
Same for Me
JC will be repairing mine in June as well. I do not see it as a major problem, I just thought I might as well since it was still under warranty.
12-21-2022, 12:45 PM
2015 20' Flying Cloud
Kingsport
, Tennessee
Not on the wrinkling/ frame-separation issue, but when I was still searching for an AS, I was aware of the possibility of a soft-floor at the rear where the bumper is attached. I'd contact the seller, and inquire about the flooring: quite a few responded back, they weren't aware but would go check, and would then find a soft spot there. Several at that point would remove their ads, so they could have them repaired before selling. Others, I'd simply wish them luck and would continue my search.
SO, yes: strike up a conversation w/ the seller. Sometimes they're not aware of a problem, and would appreciate knowing. I've found almost everyone in the community, selling an AS, to be pretty affable and straight-forward.
-Leslie
WBCCI #1051
12-21-2022, 01:32 PM
Senior Member
2012 27' FB Eddie Bauer
Sparks
, Nevada
Just had my 27FBQ fixed by Vinnie’s Airstream in Northern California. These are the brackets he has custom made. Added more verticals as well. Not inexpensive but I’m confident I will never have another problem.
12-21-2022, 09:34 PM
2018 27' Flying Cloud
INDIAN HARBOUR BEACH
Originally Posted by sheriff1
Attachment 426376
Does he sell the brackets? If, "Yes" then how?
